Old 07-05-2007, 08:38 PM   #1 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Angry Serious Problem Need help (EXPLORER)
Everytime i open a drive , say C:, D: ANY DRIVE . it opens 'Open with' instead of opeaning . everytime i have to Rt click to open
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 07-05-2007, 09:11 PM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Serious Problem Need help (EXPLORER)
Search for any hidden autorun.inf or autorun.ini files in the the drives and delete it. Before that uncheck the hide protected operating system files from the Folder Options->View menu
Nokia N86 8MP
Lucky_star is offline
Old 07-05-2007, 09:19 PM   #3 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
No autorun file
Old 07-05-2007, 11:38 PM   #4 (permalink)
The Researcher
Your solution should be in the folder options. Go there and see what is default action. If it is "open with" change it to open. Or simply click the button "set everything to defaults".
Ramakrishnan is offline
Old 08-05-2007, 07:11 PM   #5 (permalink)
Fresh Stock Since 2005
This is some virus problem....
I suspect Ravmon E... Remove it with some good latest AV...
http://www.khattam.info
khattam_ is offline
Old 08-05-2007, 07:18 PM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
Go to Tools > Folder option, make sure settings are right...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 08-05-2007, 11:22 PM   #7 (permalink)
God of Mistakes...
Garbage's Avatar
If u r not getting FOLDER OPTIONS in TOOLS menu then it's surely VIRUS Problem!
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 08-05-2007, 11:35 PM   #8 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
yeah virus problem . my kaspersky's trial period is also over damn
Old 08-05-2007, 11:36 PM   #9 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Also try this. Open regedit and goto:
HKEY_CLASSES_ROOT\Drive\shell
HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers
and make sure, that these keys don't contain any suspicious item.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Problem with explorer manuajith Software Q&A 4 05-04-2007 05:25 PM
problem with explorer Samish Tutorials 2 06-11-2006 08:26 PM
problem with explorer njm Software Q&A 2 12-09-2006 01:37 PM
Explorer Problem !!! dreams Software Q&A 6 24-12-2005 07:42 AM
Internet Explorer Problem! dare_dexter Software Q&A 10 03-09-2004 06:41 AM
- by Anorion
- by Niilesh
- by chris
