Originally Posted by zodiac_511
All drivers are installed
THE DRIVERS WILL SHOW ALLRIGHT EVEN IF SOME FILES ARE CORRUPTED
RUN DXDIAG THEN GO TO SOUND ,THERE MUST B 2 SOUND TABS ONE 4 MODEM LINE & OTHER IS YOUR SOUND CARD . CHECK IF THEIR ACCELERATION IS DISABLED OR ANYTHIN .THEN REPORT. ALTERNATIVELY YOU CAN CREATE A NEW ACCOUNT IN WINDOWS, RUN VIRUS SCAN,UNINSTALL MODEM&SOUND>REBOOT>REINSTALL>REBOOT
YOUR PROBLEM MUST B SOLVED ELSE YR MODEM/SOUND IS FAULTY
BTW R U USIN ORIGINAL WINDOWS?
