Thanks Free Radical,
Your suggestion about writing to a DVD is a good one, but I don't have a DVD writer yet. I can always play the movie on my computer, but I want to play it on the TV through my DVD player. That's why I want to convert it to a VCD.
I have a few querries for you. I have several s/w for converting the avi into a different format. But should I convert it to a
Standard MPEG-1 or into a
VCD MPEG format. Since almost all s/w have these two as separate options.
I also have VCD Cutter so splitting the file should not be a problem. I just want to know which particular format should I convert the avi file into.
Thanks again for your help.
