Old 02-05-2007, 12:02 AM   #1 (permalink)
Angry [Solved]Donno it's problem wth hardware or software ???? ( but prob !! )
Hello all
yesterday my fnd sys met with an serious problem ( it restrating automatically ) thn we have chkd for the viruses and removed three viruses , thn also the same thing continued.
we planned to format c drive and to re install xp and formatted the c drive , while installing the operating sys XP , we got the blue screen error with the following message at the time of installing drivers ( installing windows --> driver installation )
stop : 0x0000007e ( 0xC0000005, 0xF6C84593, 0xF7A7B618, 0xF7A7B314 )
mtlmnt5.sys - Address F6C84593 Base at F6C74000, Datestamp 4017D113
Beginning dump of Physical Memory
Physical memory dump complete
no problem with ram ( becoz after that prob we have used Knoppix boot cd to play songs that are present in hdd ) & hdd is also in gud cond ( thnk so )
system speci : ( donno exactly )
intel dualcore 2.6ghz processor
256 mb of ddr ram
80 gb sata hard disk drive
Please help us to recover the prob
[img]http://img78.imageshack.us/img78/2920/bluebar9et.gif[/img]
Regards ,
Muthusrinivasan
[img]http://img229.imageshack.us/img229/3883/20fl.gif[/img]
muthusrinivasan is offline
Old 02-05-2007, 12:11 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Donno it's problem wth hardware or software ???? ( but prob !! )
mtlmnt5.sys file in your Cd may be corrupt. Try installing from any other XP cd.
Nokia N86 8MP
Lucky_star is offline
Old 02-05-2007, 12:12 AM   #3 (permalink)
dissel's Avatar
Probably your windows XP installation disc damaged...try installing with a different disc.
dissel is offline
Old 02-05-2007, 06:55 AM   #4 (permalink)
Yeah already chkd with different copies !!! Same Error
is there anythng problem with modem ?? becoz one of my friend told to check the modem .
Regards ,
Muthusrinivasan
Old 02-05-2007, 08:22 AM   #5 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Yup its the modem. Just remove it and reinstall xp
http://www.file.net/process/mtlmnt5.sys.html
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 02-05-2007, 10:44 PM   #6 (permalink)
yeah , u r rgt !!
thanx
regards
Muthusrinivasan
Regards ,
Muthusrinivasan
System restarting, donno how ! sr_ultimate Software Q&A 7 11-04-2007 03:15 AM
Hardware and software rajwansh2003 Software Q&A 3 02-12-2006 08:20 PM
PC inventory software for hardware and software taken Software Q&A 4 23-05-2006 02:50 PM
hardware problem OR software problem? harikris53 Software Q&A 3 23-12-2004 08:43 PM
- by Niilesh
- by chris
- by gforz
