Old 29-04-2007, 03:06 AM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default admin in xp home
well as u know if 1 boots into safe mode of xp home then he can see the admin account which normally is not password protected is there any way by which i can password protect the admin account
http://beingmanan.com
iMav is offline
Old 29-04-2007, 07:06 AM   #2 (permalink)
Default Re: admin in xp home
In XP Home, the admin account can be password protected by going into safe mode, logging in as admin and going to user accounts in Control panel...
Arun
sakumar79 is offline
Old 29-04-2007, 11:20 AM   #3 (permalink)
iMav's Avatar
oops ya wnder y didnt think of that ... thanx
iMav is offline
Old 29-04-2007, 12:11 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Or .. Start > Run > Control Userpasswords2 {Press Enter}
Under the Users tab, click on Reset Password under Password for Administrator frame.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 29-04-2007, 03:08 PM   #5 (permalink)
iMav's Avatar
^^ hmmmm ... thats interesting
iMav is offline
Old 29-04-2007, 03:17 PM   #6 (permalink)
In search of light...
abhi.eternal's Avatar
I will suggest another easy way:
In the logon screen press ctrl+alt+del twice A box wil come up.
In the name field type "Administrator". Press Enter to login. Safe mode not needed. Now use this account as a normal account.
http://abhijeetdeb.com
abhi.eternal is offline
How does Admin Control Panel look like? kl_ravi QnA (read only) 10 22-12-2006 10:21 PM
limiting to admin only Saharika QnA (read only) 3 03-12-2006 11:20 PM
Win XP admin password recovery bhushan's Software Q&A 2 05-01-2005 09:50 PM
admin rights ! ! ! ax3 QnA (read only) 8 08-12-2004 11:31 AM
- by gforz
- by Piyush
