Old 25-04-2007, 11:20 AM   #1 (permalink)
ComputerUser's Avatar
Angry Safe mode doesn't work!
When I boot into safe mode, it just does not work. After I click on my account it logs on then suddenly restarts!Some times it shows a message but it restarts immediately.Please help.I have tried not to restart when system fails but it did not work.
ComputerUser is offline
Old 25-04-2007, 07:10 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: Safe mode doesn't work!
If you can get into Safe Mode, the first thing to do is to check Device Manager (Control Panel / System / Device Manager) for any hardware devices that may be conflicting...
http://www.windowsgalore.com/windows.95/safemode.htm
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 26-04-2007, 03:51 PM   #3 (permalink)
I got the first line of the error message.It starts with "Windows cannot create a temporary point directory..."then something. A timer was also in the error message box. It was of 30s but XP restarts before it reaches 30!
Old 26-04-2007, 04:04 PM   #4 (permalink)
Kiran.dks's Avatar
Do you have Nero installed? If yes, try uninstalling Nero. Nero "InCD4" has this tendency to override the safe mode timer and cause problems in some machines.
Kiran Kumar R
Kiran.dks is offline
Old 27-04-2007, 09:16 AM   #5 (permalink)
anandk's Avatar
well it wud help id u cud post the full msg (or scrnshot)
till then jst do the obvious. scan ur pc for malware (antivirus/antispyware) and run ccleaner. lastly get ur hjt autoanlysed at www.hijackthi.de or post it here.
Microsoft® MVP
anandk is offline
Old 27-04-2007, 02:34 PM   #6 (permalink)
I have scanned with avast! with the latest updates but no virus has been reported.
I have scanned with avast! with the latest updates but no virus has been reported.I have nero express 6 but InCD is not installed.
Last edited by ComputerUser; 27-04-2007 at 02:34 PM. Reason: Automerged Doublepost
Old 27-04-2007, 07:41 PM   #7 (permalink)
anandk's Avatar
^ and what about anti-spy scan? ccleaner? hjt logfile ?
Microsoft® MVP
anandk is offline
Old 27-04-2007, 08:47 PM   #8 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Smile Re: Safe mode doesn't work!
I heard ter is a safe mod lock for pc using pirated xp wich is connected to internet,but wont prevent u in logging into ur normal account.i dont know if dis is true.
My Stomach pains
http://tinyurl.com/32jj4m
zyberboy is online now
Old 12-05-2007, 12:32 PM   #9 (permalink)
But I don't use a pirated one!
Safe mode option ! ! ! ax3 QnA (read only) 3 03-11-2006 12:54 PM
No Safe Mode Swappy Software Q&A 2 24-08-2006 09:21 AM
Nasty virus hit......can only work in safe mode, need urgent help ranjan2001 Software Q&A 18 03-08-2006 08:08 PM
Difference Between FF Ordinary Mode & FF Safe Mode rajas700 QnA (read only) 9 27-08-2005 02:38 PM
XP SP2: SAFE MODE... ShekharPalash QnA (read only) 8 25-09-2004 11:02 PM
