Yes I too had the same problem -
Here what you can do.
open task manager, by clicking ctrl+alt+del.
Goto process tab and click on "Image Name" so that all processes are arranged in alphabetical order.
Now select the process, whose Image name is svchost.exe and User Name is {Windows Account Name}, and kill them by clicking on End Process button.
Be sure that you dont kill other svchost.exe process having User Name SYSTEM, LOCAL SERVICE, NETWORK, otherwise your system will shutdown.
Now using a search engine, look for a folder starting with name "heap" (in my case it was c:\heap41a ), this folder will be containing files svchost.exe and some text files. Just delete them.
Now start Firefox, this should have solved the problem.
Happy killing !!
