Old 24-04-2007, 12:28 AM   #1 (permalink)
Angad singh's Avatar
Default Unknown virus problem
guys there is some kind of virus in my pc and from my pc it came it my portable hard disk....wat it has done is it has disabeled double click on my local disk c and local dsk g (portable disk).. ie i have to open the disk by right click and then choose open... doubl click on icon dosent works..
i am using avast antivirus and it does nt detects this virus.. even used spybot search and destroy \
wat is it can u guys help me out...........
one more thing guys i thought to use system restore.... and it worked..
but there was still virus in portable HD and if i connected it to get my back up virus would again cum in my pc and that is what happened and i thought after backup and formatting the portable HD i would again restore the pc and problem wud be solved but guess wat its my bad day oll the system restoe points are vanished they were no more here....
HELP!!!
Angad singh is offline
Old 24-04-2007, 01:40 AM   #2 (permalink)
TooR
alok4best's Avatar
Default Re: Unknown virus problem
right click and open ur drive...show all hidden files and folders..if some autorun.inf file is there,delete that.
I wish !!
alok4best is offline
Old 24-04-2007, 08:56 AM   #3 (permalink)
no dude there is no such file named autorun.inf
Old 24-04-2007, 09:33 AM   #4 (permalink)
Distinguished Member
anandk's Avatar
pls post ur hjt log here or get it auto-analysed at www.hijackthis.de This will give a clearer picture.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 26-04-2007, 07:29 PM   #5 (permalink)
Thank u guys i got the problem... it was some trjan virus made by my friend and from his HD it came in my pc it was a wscript.vbs.dll file..
Access denied in one unknown folder-problem H.Lalnunmawia QnA (read only) 4 27-12-2006 09:59 AM
One unknown folder causing problem H.Lalnunmawia Software Q&A 1 27-12-2006 09:14 AM
Unknown problem in explorer.....HELP! fordac Software Q&A 3 02-12-2006 10:40 PM
Unknown problem.. Ashwin Saxena QnA (read only) 6 26-06-2005 09:36 PM
*** Unknown Problem *** vishal_bhatia87 QnA (read only) 2 16-05-2005 10:03 PM
- by gforz
- by Piyush
