Old 23-04-2007, 02:18 PM   #1 (permalink)
Default Problems with Y! messenger
I have yahoo messenger 8 and I have been using it for long time... but since yesterday I've been facing problems signing in. I installed 2 Firewalls yesterday, Zone Alarm and Armor2Net and none of the firewalls are blocking Y! Messenger... I also tried to change the Connection Preferences but nothing is working and I don't even know what Proxies are.. Plz Plz help me !
bazigaar_no_1 is offline
Old 23-04-2007, 02:51 PM   #2 (permalink)
Search for Adventure
ITTechPerson's Avatar
Default Re: Problems with Y! messenger
It sounds like the problem u r facing since u have installed the firewalls.
first remoove 1 of them & test msngr, if nothing happen then remoove the other 1. (remoove the entry from reg also)
Nobody is Perfect. I am "Nobody"
ITTechPerson is offline
Old 23-04-2007, 09:54 PM   #3 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
use only zonalarm dude....n u want the firewall to block y!messenger or u wanna unblock it???
u don't need to bother about proxies since its u r using from home
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 23-04-2007, 10:16 PM   #4 (permalink)
[A]bu's Avatar
the same problem had occured on my pc. Weather the network was down i don't know...
Do or Die
http://www.hamrobrt.com/howto-install-flash-player-in-ipad/
[A]bu is offline
Old 23-04-2007, 11:00 PM   #5 (permalink)
I want to firewall to allow Y! messenger to send data but somehow Y! Messenger can't connect to the net (everything else works fine....) But it's not on the blocked programs list of ZoneAlarm... ?? I can't seem to figure out what the problem is ... I still cant get it to connect...
Old 24-04-2007, 01:12 AM   #6 (permalink)
TooR
alok4best's Avatar
remove the other firewall...keep ZA..its always better to have only one Antivirus program and firewall on ur pc..or else conflicts will occur..go to ZA program control and make sure that the trust level of yahoo messenger is either trusted or super.
I wish !!
alok4best is offline
Old 24-04-2007, 02:18 PM   #7 (permalink)
i removed both the firewalls, removed y! messenger, restarted my system a couple of times, then I went to http://messenger.yahoo.com/ and tried to download the latest Yahoo Messenger 8.1 . After d/ling the .exe file, i executed it and it showed an error saying that my PC was unable to connect to the Y! servers and gave me a link to another y! messenger that's an 8 MB download... I am currently downloading that alternate Y! messenger... let's see what happens.. !
Update : I installed that alternate version too... but it gives a different error while signing in... sumthing like... "we are not able to connect you to Yahoo ! " and 3 options like "try again", "modem users" and "help"... I still can't get in... though y! mail works fine..
Last edited by bazigaar_no_1; 24-04-2007 at 02:18 PM. Reason: Automerged Doublepost
Old 24-04-2007, 06:03 PM   #8 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Check the Massanger - Preference - Connection - and use no proxy. If it not works then use no network detection.
Check your country as India.
If you just want to use massanger you can go to http://wwwl.meebo.com/index-en.html
and use a web massanger from there.
Quiz_Master is offline
Old 24-04-2007, 07:03 PM   #9 (permalink)
I also tried Trillian but even it cannot connect me to the Y! network (
@ quiz master : I tried to connect using all of the 4 connection preferences but it still can't connect... Will I be able to chat to wid my Y! friends using Meebo ??
thanks quiz master !!
I worship you !!
meebo is working good and I could chat using it.. thanks a tonne..
but i still can't get in through my messenger (
I uninstalled y! messenger 8.0 and installed version 7.0 but the problem persists.. I read it somewhere that y! messenger uses port 5050 for connecting, though I have uninstalled the firewalls how can I check if the port 5050 is blocked or not.. ?
Last edited by bazigaar_no_1; 24-04-2007 at 07:03 PM. Reason: Automerged Doublepost
yahoo messenger problems ........plz help vavinashraju Software Q&A 3 26-01-2007 12:26 AM
MSN messenger problems... adit_sen Software Q&A 2 27-05-2006 05:40 PM
Problems with Y! Messenger pratheesh_prakash QnA (read only) 5 12-03-2006 03:30 AM
Yahoo messenger 7 problems ashu888ashu888 Software Q&A 11 15-01-2006 01:38 PM
- by gforz
- by Piyush
