Re: photosop problem
tht's not the thing u should do.... u cannot perform a simple copy paste operation when u want some executables to work. U need to INSTALL them using its setup. the registry needs to be informed tht u r installing the program... Copying them will not simply update the registry and hence it'll give u errors.... Try installing a fresh copy
TechExplorer.in
