Old 21-04-2007, 07:23 AM   #1 (permalink)
hsr
Senior Owner
hsr's Avatar
Default Help !!! Low On Resources
This is my system configuration:-WINDOWS XP MEDIA CENTER EDITION 2005AMD ATHLON XP 2400+512 MB DDR128 MB NvDIA GeFORCE FX 5200ASUS A7V266-MXASUS CD RWMY OWN 2.1 WOOFER SUR. SYSTEMNow the question:These days i'm facing a lot of problems with my memmory.It is being utilized by the system heavily.This results in System crash.I cannot run games like Most wanted Carbon POP in medium settings smoothly and it takes a lot of time to load.The condition for Far cry is pitiful it s**** at low settings!Please give me a solution execpt changing the priority class.
Read Rules > FAQs > Stickies before posting a new thread. PM me anytime for an issue, and I'll be idle on irc too.
My dream rig.
ლ(ಠ_ಠ)ლ Webchat for Digit.
hsr is online now
Old 21-04-2007, 03:41 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Re: Help !!! Low On Resources
There are lot of solutions you can try.
First check via Task manager which process is using more CPU usage and RAM.
Also check your startup processes using Hijackthis. If possible post Hijackthis log because it will show all startup processes.
Uninstall any software which you think you do not need.
Also disable some services by running services.msc in Start>>Run and disable some common services like MDM(installed by office), Application layer Gateway, Error reporting service, Fast user switching(If you don't use it), Indexing service(it helps a lot), Messenger(don't worry its not the MSN messenger but the Windows Messenger), Remote Registry(highly unsafe), Windows Firewall(if you have installed 3rd party firewall like ZoneAlarm) and Windows Time services.
Defragment all your hard drives.
Use CCleaner to clean all junk files. Even if you don't have it empty these folders:
C:\Windows\Temp
C:\Documents and Settings\<username>\Local Settings\Temp
C:\Windows\Prefetch
navjotjsingh is offline
Linux Resources Sourabh Open Source 8 30-08-2008 10:03 AM
WWE : RAW for PC...Need online resources Quiz_Master Gamerz 8 31-01-2006 10:17 AM
system resources for XP SP1 and SP2 Saharika Software Q&A 5 13-11-2005 10:27 PM
- by Piyush
- by gforz
