Old 17-04-2007, 07:25 AM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default problem in shutdown
yes'tr day whn i send the pc to stand by mode a deep blue screen apear and says something like this " an error has occer during shutdown restart the computer and run a system diagnosis tool and check for mismatch of memory"
something more was written there but i dont remember all, writing colors are whight in deep blue screen, thn i restart the pc and till then it never happens,
there is also a problem of restarting, ie not every time but once every 2 to 3 days comp restart automatically.
what is a system diagnosis tool, is it a kind of software? is there any free version of that is available?
gau_pppu is offline
Old 17-04-2007, 01:28 PM   #2 (permalink)
Proud Mac Pro Owner
nepcker's Avatar
Default Re: problem in shutdown
Congratulations! You have seen the Blue Screen Of Depth.
This happens a lot if use Windows 98. The frequency is drastically reduced on Windows XP, but still you see them occasionally.
The only help I can offer to you now is to get a mac.
If you want to stick with Windows, then the next time you see a BSOD, write down the code of the BSOD and post it here. That's the only way anyone can solve your problem.
Microsoft Certified Professional Mac Addict
nepcker is offline
Old 17-04-2007, 01:38 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: problem in shutdown
Is it blue screen of Depth or Death.........
satyamy is offline
Old 17-04-2007, 08:48 PM   #4 (permalink)
Proud Mac Pro Owner
nepcker's Avatar
Sorry -- a typo.
It's the Blue Screen of Death.
nepcker is offline
Old 17-04-2007, 09:24 PM   #5 (permalink)
overclocker's Avatar
Yeah it is a software..
Actually system diagnosis tool is a utility which is used for analyze and
benchmark of ur system. It can analyze and benchmark ur machine hardware such as ur CPU performance, main board information, hard disk performance and much more..
overclocker is offline
Old 17-04-2007, 09:32 PM   #6 (permalink)
Proud Mac Pro Owner
nepcker's Avatar
^^ What are you talking about?
BSOD's just an annoying error message with a scary look to it.
nepcker is offline
Old 17-04-2007, 09:38 PM   #7 (permalink)
Fresh Stock Since 2005
Your RAM may be corrupt.. But it might not be the case.. If this does not come up again, don't bother. But if it does, check your ram with memtest and change if errors are found..
http://www.memtest86.com/
or
http://www.memtest.org/
http://www.khattam.info
khattam_ is offline
Old 17-04-2007, 10:08 PM   #8 (permalink)
aryayush's Avatar
You got a BSoD? Never mind.
If you get it again, re-install the operating system.
That's standard procedure.
aryayush is offline
Old 17-04-2007, 10:23 PM   #9 (permalink)
String Phreak
mediator's Avatar
Apply the latest updates! AFAIK, automatic restart can also occur due to overheating. So I suggest u clean the internals of ur PC with a vaccuum cleaner and a dry cloth!
mediator is offline
Shutdown problem ratedrsuperstar QnA (read only) 3 06-12-2006 11:43 AM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
cc app problem on shutdown please help mannu143 Software Q&A 2 07-02-2006 04:27 AM
Shutdown Problem choudang QnA (read only) 6 04-12-2005 11:54 PM
shutdown problem atul QnA (read only) 3 31-08-2004 12:41 AM
- by Piyush
- by gforz
