15-04-2007, 12:11 PM
TeCh Blogger : Gtechinfo
stand by and hibernate
Is there any difference between standby and hibernate, if thn which one is better, can we switch off the main power after sending the pc into standby or hibernate mode.
15-04-2007, 12:27 PM
:-o
Re: stand by and hibernate
15-04-2007, 12:42 PM
Stand-by Mode: RAM is still powered. Power is still being consumed.
Hibernate Mode: Power is not comsumed. RAM data will be written on Hard disk while hibernating. The data will be written back to RAM while recovering from hibernation mode.
Hibernation mode is better than Stand-by-mode becoz it doesn't consume any power.
..can we switch off the main power after sending the pc into standby or hibernate mode.
Hibernation mode : You can switch off the main power supply.
Stand-by mode: You should not switch off the main power supply.
Kiran Kumar R
15-04-2007, 12:53 PM
Kiran explained everything up there...
i agree with it.
Hibernation is better if you have a goood disk space
15-04-2007, 12:58 PM
Gud to know this.
Can I keep downloading files from a ftp server or rapidshare in the background if I am in the stand by mode?
I have a sleep mode button on my keyboard, does it means stand by by pressing that button?
15-04-2007, 06:33 PM
how will i send the system to hibernate mode,
15-04-2007, 07:20 PM
Turn off computer> u will see 3 commands, press shift button then stand by will change to hibernation.
before doing that control panel> power> hibernation should be enabled
15-04-2007, 07:22 PM
Right-click on desktop>Properties
>Screen Saver tab
>Power button
>Hibernate tab
>Check in "Enable Hibernation"
>Click Apply and then OK
Now to put the system in Hibernation mode, click "Start" and then "Turn OFF".
Now you will get three options viz.
Stand-by
Turn OFF
and Restart
Press "Shift" key now. The "Stand-by" option will change to "Hibernate".
Click it. The system will go to Hibernate mode.
Kiran Kumar R
15-04-2007, 08:00 PM
The Transcendental
>Screen Saver tab
>Power button
>Hibernate tab
Stand-by
Turn OFF
and Restart
Or simply Press 'H' to Hibernate, 'U' to shUtdown and 'R' to Restart
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
15-04-2007, 09:26 PM
If u r leaving ur PC idle for say 10 mins then StandBy is better (it switch off HDD and other peripherals suspends to the power saving mode).
Hibernation is an alternative to shutdown if u like the booting sequence faster and not going for a vacation. Remember hibernation requires the same amnt of memory as ur RAM is. So it consumes HDD space. Also it may give rise to instability in OS after some days.Everything is in the RAM is copied to HDD and dumped back to RAM wen u switch on the PC.
So best is to shutdown ur comp when u sleep.
Originally Posted by ranjan2001
Gud to know this.
Yes sleep is standby.
But i dont hav a sleep button on my logitech kb ?
May be its obsolete now.
not sure if the download will be continued in standby mode, try it n u will come to know as am too lazy to do this.
Reason: Automerged Doublepost
15-04-2007, 09:39 PM
Nope. Downloads will not continue in "Stand-by" mode. Becoz "Stand-by" mode only keeps the memory alive and all other drivers including Network connections, Bluetooth drivers etc are not active.
Kiran Kumar R
15-04-2007, 10:14 PM
The Transcendental
If you enable hibernation, and also check the option to hibernate whan your computer powers down, the sleep button of your keyboard will hibernate instead of standby. (Atleast Mine does)
15-04-2007, 10:30 PM
I thought so, as of now I use ASUS ALNos utility to put the comp in low power mode & it keep everythig working including downloading but still saves power 80%
Let me try that, its good if it does so.
15-04-2007, 10:38 PM
The Transcendental
^Another reason to go 4 ASUS. You know of something for intel mobos. when I sleep, i turn of my Monitor and speakers but everything else keeps running.
