Originally Posted by c.rajesh
I tried installing the UXTheme Multipatcher 5.5 so that i could use a third-party visual theme on my windows xp home(sp2) but i get this message saying:
'UXTheme Multipatcher 5.5 has detected that there's any Windows NT setup file in C:\WINDOWS\i386. It's not recommended you continue with this. Please eject your windows NT cd or move the folder to some other location. Click OK to exit.'
I had not inserted any cd during this time so what do I do?? Will it be safe if I move the folder and where should I move it to?
it seems you're using a Branded PC, with Pre-loaded Windows XP (OEM).
to install the Patcher, just rename
i386 to
i386a or any thing you desire & install the Patcher->restart-> intall theme &
Rename i386a folder back to original name (i386).
i too had this problem & Mr. Vista (Vishal_Gupta) had advised me to do this & it worked.
