Old 14-04-2007, 11:03 AM   #1 (permalink)
Question Removing MS office 2003 entry from Add/Remove Panel
I have uninstalled MS office 2003 but the entry still remain in Add Remove Programme panel. Now whenever i try to re install the MS Office 2003 it says reqd patch is not available, and installation stops. This started when I formated one of my drive. How can I remove this entry and re install the office. pl help.
I am using P IV 2.4 256 mb 266 Mhz DDR SDRAM on Win XP Pro SP 2
psnegi26136 is offline
Old 14-04-2007, 03:14 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Removing MS office 2003 entry from Add/Remove Panel
If u want to remove the entry from "Add/remove" list, then open regedit and goto:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
Under this key, u'll get several other keys. Just look for a key, which has "Display name" as "Microsoft Office" (or something like that). Delete the key and it'll remove Office entry from Add/remove list.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 16-04-2007, 10:48 AM   #3 (permalink)
Dear Vishal,
I did what you said. But I didnot find any entry of MS Office in the registry.
Old 16-04-2007, 11:54 AM   #4 (permalink)
Kiran.dks's Avatar
Download and install Office 2003 Editions Resource Kit. By using it you can uninstall MS Office completely.
Kiran Kumar R
Kiran.dks is offline
Old 16-04-2007, 12:20 PM   #5 (permalink)
No Dear Kiran,
still nothing happened. In this forum somewhere a link was given to use addremovecleaner. i used that and it removed the repair/remove option. but entry is still there. meanwhile I have installed Office XP. it has installed successfully and working. but that annoying entry of MS Office 2003 is still there.
Old 16-04-2007, 12:50 PM   #6 (permalink)
Kiran.dks's Avatar
In that case, you should edit the registry manually and remove the entry.
Refer the snap-shot and propagate to that entry and delete it. The registry entry number may vary. But look at the right pane of the registry editor. You should see the "Microsoft Office 2003" entry.
Close the registry editor after the process and log-off and log-in again.
The entry in the Add/remove Programs should have vanished.
Kiran Kumar R
Old 16-04-2007, 02:00 PM   #7 (permalink)
You can also try to use TweakUI which lists add/remove entries and allows you to remove them... In addition, I recommend that you try a registry cleaner to remove invalid entries
Arun
sakumar79 is offline
Old 17-04-2007, 02:25 AM   #8 (permalink)
just install the thing and again and reinstall it .. that shd give u the best proper uninstall ..
AMD Athlon 3500+ 939
Asus A8N-E
HDD: 860GB = 250 x2 + 160 x 2 + 40
Nvidia XFX 7600GT
2GB DDR RAM 400Mhz Transcend
17" LCD Viewsonic
ASUS Sata DVD writer
Logitech MX 518 + Steelpad Qck+
CyCo is offline
Old 17-04-2007, 07:08 AM   #9 (permalink)
@Cyco, did you not read his post carefully? He is not able to reinstall it...
Arun
Old 17-04-2007, 08:29 PM   #10 (permalink)
Thank friends for all the help and advices. I think for the time being I have to live with this entry. I have searched the whole registry as you have advised but did not find any entry relating to MS office 2003. I guess this entry was already deleted by some reg cleaner I tried. and I tried quite a few. I even tried to create such entry and after rebooting deleted it, but nothing happened. For the time being I am working on Office XP.
Old 02-05-2007, 10:38 PM   #11 (permalink)
Thumbs up Re: Removing MS office 2003 entry from Add/Remove Panel
Hey guys,
guess what ? I came across a wonderful tool called Uninstall Tool. Its just 300kb and its free. you can down load it from this site
http://www.crystalidea.com/index.php...age&name=utool
It directed me to the registry entry in one click. I deleted that entry and bingo. The problem solved, and the offending MS Office 2003 entry is off from my Add\Remove programme list.
Seeing that almost 100 guys have seen my thread I thought, I will post this solution. Hope it will help somebody.
Remove entry in dual boot menu abhijit_reddevil Software Q&A 8 19-11-2006 06:05 PM
Office 2003 sp2 hemant_mathur Software Q&A 2 01-05-2006 10:35 PM
Removing the entry from explorer uvg_don Software Q&A 1 30-03-2006 07:02 AM
Remove Save Schemes & Other Entry from Desktop Context Menu! Vishal Gupta Tutorials 2 20-09-2005 08:43 PM
Microsoft office 2003 Help !!!!! ( VISIO 2003 ) varun_ag Software Q&A 6 05-03-2005 01:56 AM
- by gforz
