Old 14-04-2007, 08:11 AM   #1 (permalink)
Drool!...Vista
*GandaBerunda*'s Avatar
Unhappy Norton Help..
i had installed norton antivirus trial version. i later removed it forcibly thorugh your unistaller! as something was going wrong with the uninstallation. now evn though i have removed norton still, it' processes
C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
C:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe
C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
are still running. why is this happening? can i end those processes and delete the directories?
Visit my blog http:\\geekgarbage.blogspot.com, but don't click on the ads :)
*GandaBerunda* is offline
Old 14-04-2007, 09:33 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Norton Help..
You have not mentioned the version...
how ever,youmay try Norton Removal tool from Symantec to remove Norton from your PC..
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 14-04-2007, 01:47 PM   #3 (permalink)
You can go to safe mode and delete the problematic files/folders and remove entries in the startup with msconfig... You might want to run a registry cleaner tool to remove broken entries...
Arun
sakumar79 is offline
Old 14-04-2007, 02:19 PM   #4 (permalink)
gooby pls
Third Eye's Avatar
Just download Norton Removal Tool
This tool uninstalls all Norton 2006/2005/2004/2003 products from your computer.
Third Eye is offline
norton or AVG azzu Software Q&A 27 17-10-2006 03:34 PM
Norton Pop-ups suniltr77 Software Q&A 11 08-09-2006 08:43 PM
Norton ghost kaliaraj Software Q&A 4 06-06-2006 03:27 PM
Norton Help ! ! ! ax3 Software Q&A 15 28-08-2005 09:41 AM
Which is better ? Norton or AVG ? Omsck Software Q&A 6 10-03-2005 09:14 PM
- by gforz
