Old 11-04-2007, 10:33 PM   #1 (permalink)
Default Problem With Drives
I Got my PC 1 month ago n i hav 1 problem that except c drive all the drives are getting open in next window i contacted many guys all told me to fromat my hard drive is their any other way to solve this poroblem plz help me out............................................... ..........................
yatin3987 is offline
Old 11-04-2007, 10:57 PM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: Problem With Drives
open folder options in an explorer window(as far as i remember it's in views).then select to open each folder in the same window.this should solve the problem.
Harvik780 is offline
Old 11-04-2007, 11:18 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Try this
>>"Tools=>Folder Options"
>>Select the "File Types" tab
>>Select the file type of "Folder".
>>Click on "Advanced"
>>"Actions" select "Open"
>>"Set Default"
>> Click OK
wizrulz is offline
Drives Gone ..... BBThumbHealer QnA (read only) 4 30-03-2007 12:22 PM
Problem with Opening Drives in My Computer shakti Software Q&A 6 26-04-2006 10:37 PM
DVD drives hel_cell QnA (read only) 2 26-03-2005 01:29 AM
USB drives 512 to 1GB HELP!!!!!!!!!!!! dOm1naTOr Peripherals 5 05-03-2005 01:31 PM
Digit's DVD drives the market's drives shakshy QnA (read only) 3 30-10-2004 09:27 PM
- by gforz
