Old 11-04-2007, 12:44 PM   #1 (permalink)
santu_29's Avatar
Unhappy trojan/adware help..
The Smitfraud-C.Toolbar888 was found by Spybot and I have used the Smitfraudfix and Spybot to remove it. However it returns after a while. Please help..
Unless you have a dream, you are not going to achieve anything in life.
Shoot for the moon, even if you miss, youll fall in the stars.
******************ÏMPÕ§§ÏßL£ ϧ ÑÕTHÏÑG ******************
santu_29 is offline
Old 11-04-2007, 02:42 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: trojan/adware help..
disable system restore.
run diskcleanup utilty and ccleaner
reboot
scedule a boot-time scan of spybot.
shud help
if it dznt use removal tool from http://www.spywareremove.com/removeSmitfraud.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 11-04-2007, 02:45 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
keep the TeaTimer or rather autoprotection of Spybot turned on and scan the system regulerlly...
now why it comes back ??
it is possible that we may have your System Restore Option turned on... therefore it may hide there as while the System Restore option is turned on no security software is allowed to modify it therefore Virus of Spyware may hide there...
Disable the System Restore, run a Onloine Scan from Kaspersky or Symantec... it may solve the problem
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-04-2007, 04:04 PM   #4 (permalink)
santu_29's Avatar
removeSmitfraud.html[/url]
how do i do that, couldnt find any option for boot-time scanning
santu_29 is offline
Old 11-04-2007, 04:27 PM   #5 (permalink)
anandk's Avatar
i dont have spybot instld right now. but its DEFNTLY there in one of the settings/options in spybot. i dont remember where it is. try to look around. u will have to check the box 'schedule a boot-time scan of spybot'. else i hope some spybot user will help u
Microsoft® MVP
anandk is offline
Old 11-04-2007, 09:26 PM   #6 (permalink)
bukaida's Avatar
Use a more professional software like spy sweeper.much more powerful and removes almost all threats.Get it from--
http://www.webroot-store.com/index.php?ref=GA_0200_01
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Harassed by Adware er_gurpreet Software Q&A 4 17-06-2006 12:31 PM
Adware / Spyware ? mohanty1942 QnA (read only) 4 17-03-2006 09:32 PM
Virus or Adware shivkumar Software Q&A 5 16-10-2005 10:28 AM
best spyware/adware/trojan cleaner with active monitoring. thegame_rulez QnA (read only) 2 12-09-2005 07:27 PM
adware prob readermaniax QnA (read only) 2 09-08-2005 06:41 PM
- by gforz
