Old 08-04-2007, 08:42 PM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default Problem in writing DVD
its taking lot of time to rite DVD arround 45 min, to rite a full dvd (4.5gb), earlier i posted a same topic but did not get any posetive reply frm hre, whn it is ritind the dvd the system is getting verry slow, cannot open anything during that time as if ti is running on a 128 mb or lesser ram instade of a 512 mb ram.
my riting software is nero and asampoo burnng studio 2007,
is the writer is deffective?
where should i get the latest firmware my drive is sony DRU-810A.
gau_pppu is offline
Old 08-04-2007, 09:09 PM   #2 (permalink)
sumeetindia's Avatar
Default Re: Problem in writing DVD
What is the speed you selected while writing
Can u post the log file created by "nero info tool".So that we can see the configuration.and details
Sumeet
www.fultoomobile.com - Free Hindi Ringtones and mobile wallpapers
sumeetindia is offline
Old 08-04-2007, 09:19 PM   #3 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
If ur drive is quite old then the most probable case is it has gone defective.Most DVD writers over long time usage turn slow.I am saying this with my own experience.I have 2 guys the dvd writers of whom i have seen to turn slow over 1 year.
And the thing u said about ur comp getting slow while writing dvds is because of too much cpu usage.
Check the following uder device manager(to open device manager right click on my computer and select manage click on device manager.)
under IDE ATA/ATAPI CONTROLLERS double click on ATA CHANNEL on which ur writer is installed.
Under advance tab check DMA IF AVAILABLE.
Harvik780 is offline
Old 08-04-2007, 09:20 PM   #4 (permalink)
gau_pppu's Avatar
DVD i use is 16x but i erite in 12x initially it took maximum of 15min but naodays it is more than 45 min.
by the way, how would I send the log file, frm nero info tool.
gau_pppu is offline
Old 08-04-2007, 09:21 PM   #5 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
if the drive does not go in dma mode then most chances are that the ide cable on which ur drive is installed has become defective
Old 08-04-2007, 10:09 PM   #6 (permalink)
Start the "nero info tool" its in the start->program->nero->tools
Then press the save button on the top
The the next dialog box select save and browse to a location and save that txt file
The copy the content in that text file and paste it in the reply box of this forum
Sumeet
Old 08-04-2007, 10:21 PM   #7 (permalink)
i think its dma problem...i had the same prob....earlier....
actually...at that time i tried to change to dma....but it didnt show the option./.so i changed the ide slot ( from primary to secondary)...and the prob was solved....
manmay is offline
Old 08-04-2007, 10:25 PM   #8 (permalink)
gau_pppu's Avatar
Nero InfoTool 4.2.1.0
Drive Information
Drive : SONY DVD RW DRU-810A
Type : DVD±R/RW DL Recorder
Firmware Version : 1.0f
Buffer Size : 2 MB
Date : ?
Serial Number : 812077036810A ET0511
Vendor Specific : May09 ,2006
Drive Letter : G:\
Mechanism : Tray
Read Speed : 40 X
Write Speed : 40 X
Read CD Text : Yes
Return C2 Pointers : No
Read CD-R : Yes
Read CD-RW : Yes
Read DVD-ROM : Yes
Read DVD-RAM : No
Read DVD-R : Yes
Read DVD-RW : Yes
Read DVD-R DL : Yes
Read DVD+R : Yes
Read DVD+RW : Yes
Read DVD+R DL : Yes
Read BD-ROM : No
Read BD-R : No
Read BD-RE : No
Read HD DVD-ROM : No
Read HD DVD-R : No
Read HD DVD-RW : No
Read HD-BURN : No
Read Digital Audio : Yes
Read CD+G : Yes
Read VideoCD : Yes
Write CD-R : Yes
Write CD-RW : Yes
Write DVD-R : Yes
Write DVD-RW : Yes
Write DVD-R DL : Yes
Write DVD+R : Yes
Write DVD+RW : Yes
Write DVD+R DL : Yes
Write DVD-RAM : No
Write BD-R : No
Write BD-RE : No
Write HD DVD-R : No
Write HD DVD-RW : No
Write HD-BURN-R : No
Write HD-BURN-RW : No
Buffer Underrun Protection : Yes
Mount Rainier : No
SolidBurn : No
Labelflash : No
Modes : Packet, TAO, DAO, SAO, RAW SAO, RAW SAO 16, RAW SAO 96, RAW DAO 16, RAW DAO 96
Region Protection Control : RPC II
Region : None
Changes User : 5
Changes Vendor : 4
Disc Information (G:\)
Type : no disc inserted
Drive Information
Drive : SONY CD-RW CRX320EE
Type : Combo Drive
Firmware Version : RYK4
Buffer Size : 1536 KB
Date : ?
Serial Number : 2005110400000208
Vendor Specific : Sep21 ,2005
Drive Letter : H:\
Mechanism : Tray
Read Speed : n/a
Write Speed : 52 , 40 , 32 , 24 , 16 , 12 , 4 X
Read CD Text : Yes
Return C2 Pointers : Yes
Read CD-R : Yes
Read CD-RW : Yes
Read DVD-ROM : Yes
Read DVD-RAM : No
Read DVD-R : Yes
Read DVD-RW : Yes
Read DVD-R DL : Yes
Read DVD+R : Yes
Read DVD+RW : Yes
Read DVD+R DL : Yes
Read BD-ROM : No
Read BD-R : No
Read BD-RE : No
Read HD DVD-R : No
Read HD DVD-RW : No
Read HD-BURN : No
Read CD+G : Yes
Read VideoCD : Yes
Write CD-R : Yes
Write CD-RW : Yes
Write DVD-R : No
Write DVD-RW : No
Write DVD-R DL : No
Write DVD+R : No
Write DVD+RW : No
Write DVD+R DL : No
Write DVD-RAM : No
Write BD-R : No
Write BD-RE : No
Write HD DVD-R : No
Mount Rainier : Yes
SolidBurn : No
Labelflash : No
Region : None
Changes User : 5
Changes Vendor : 4
Disc Information (H:\)
Drive Information
Drive : Generic DVD-ROM
Type : DVD-ROM Drive
Buffer Size : 512 KB
Date : ?
Serial Number
Vendor Specific :
Drive Letter : I:\
Mechanism : Tray
Read Speed : 32 , 8 X
Write Speed : n/a
Read CD Text : Yes
Read CD-R : Yes
Read CD-RW : Yes
Read DVD-ROM : Yes
Read DVD-RAM : Yes
Read DVD-R : Yes
Read DVD-RW : Yes
Read DVD-R DL : No
Read DVD+R : Yes
Read DVD+RW : Yes
Read DVD+R DL : No
Read BD-ROM : No
Read BD-R : No
Read BD-RE : No
Read HD DVD-R : No
Read HD DVD-RW : No
Read HD-BURN : No
Read CD+G : Yes
Read VideoCD : Yes
Write CD-R : No
Write CD-RW : No
Write DVD-R : No
Write DVD-RW : No
Write DVD-R DL : No
Write DVD+R : No
Write DVD+RW : No
Write DVD+R DL : No
Write DVD-RAM : No
Write BD-R : No
Write BD-RE : No
Write HD DVD-R : No
Buffer Underrun Protection : No
Mount Rainier : No
SolidBurn : No
Labelflash : No
Modes : n/a
Region : None
Changes User : 5
Changes Vendor : 4
Disc Information (I:\)
System Information
AllocateCdRoms : 0
Operating System : Windows XP Professional (5.01.2600 Service Pack 2)
Country : United States
Language : English
ANSI Code Page : 1252
OEM Code Page : 437
DirectX : DirectX 9.0c
Internet Explorer : 6.0.2900.2180 (Build 62900.2180)
Interface Information
System devices
Intel (R) System Management BIOS Driver
Driver
Description : Intel (R) System Management BIOS Driver
Company : Intel Corporation
Version : 1.0.0.14
Date : 9-11-2003
File Name : oem8.inf
Microsoft ACPI-Compliant System
Driver
Description : Microsoft ACPI-Compliant System
Company : Microsoft
Version : 5.1.2535.0
Date : 7-1-2001
File Name : acpi.inf
ACPI Fan
Driver
Description : ACPI Fan
Company : Microsoft
Version : 5.1.2600.2180
Date : 7-1-2001
File Name : machine.inf
ACPI Thermal Zone
Driver
Description : ACPI Thermal Zone
Company : Microsoft
Date : 7-1-2001
ACPI Power Button
Driver
Description : ACPI Power Button
Company : Microsoft
Date : 7-1-2001
PCI bus
Driver
Description : PCI bus
Company : Microsoft
Date : 7-1-2001
PCI standard host CPU bridge
Driver
Description : PCI standard host CPU bridge
Company : Microsoft
Date : 7-1-2001
PCI standard PCI-to-PCI bridge
Driver
Description : PCI standard PCI-to-PCI bridge
Company : Microsoft
Date : 7-1-2001
ATI SMBus
Driver
Description : ATI SMBus
Company : ATI Technologies Inc
Version : 5.10.1000.5
Date : 12-20-2004
File Name : oem1.inf
Microsoft UAA Bus Driver for High Definition Audio
Driver
Description : Microsoft UAA Bus Driver for High Definition Audio
Company : Microsoft
Version : 5.10.0.5010
Date : 3-5-2004
File Name : hdaudbus.inf
PCI standard ISA bridge
Driver
Description : PCI standard ISA bridge
Company : Microsoft
Date : 7-1-2001
ISAPNP Read Data Port
Driver
Description : ISAPNP Read Data Port
Company : Microsoft
Date : 7-1-2001
Motherboard resources
Driver
Description : Motherboard resources
Company : Microsoft
Date : 7-1-2001
Programmable interrupt controller
Driver
Description : Programmable interrupt controller
Company : Microsoft
Date : 7-1-2001
Direct memory access controller
Driver
Description : Direct memory access controller
Company : Microsoft
Date : 7-1-2001
System timer
Driver
Description : System timer
Company : Microsoft
Date : 7-1-2001
System CMOS/real time clock
Driver
Description : System CMOS/real time clock
Company : Microsoft
Date : 7-1-2001
System speaker
Driver
Description : System speaker
Company : Microsoft
Date : 7-1-2001
Numeric data processor
Driver
Description : Numeric data processor
Company : Microsoft
Date : 7-1-2001
Driver
Company : Microsoft
Date : 7-1-2001
Extended IO Bus
Driver
Description : Extended IO Bus
Company : Microsoft
Date : 7-1-2001
Driver
Company : Microsoft
Date : 7-1-2001
Printer Port Logical Interface
Driver
Description : Printer Port Logical Interface
Company : Microsoft
Date : 7-1-2001
Driver
Company : Microsoft
Date : 7-1-2001
System board
Driver
Description : System board
Company : Microsoft
Date : 7-1-2001
ACPI Fixed Feature Button
Driver
Description : ACPI Fixed Feature Button
Company : Microsoft
Date : 7-1-2001
Logical Disk Manager
Driver
Description : Logical Disk Manager
Company : Microsoft
Date : 7-1-2001
Volume Manager
Driver
Description : Volume Manager
Company : Microsoft
Date : 7-1-2001
Terminal Server Device Redirector
Driver
Description : Terminal Server Device Redirector
Company : Microsoft
Date : 7-1-2001
Terminal Server Keyboard Driver
Driver
Description : Terminal Server Keyboard Driver
Company : Microsoft
Date : 7-1-2001
Terminal Server Mouse Driver
Driver
Description : Terminal Server Mouse Driver
Company : Microsoft
Date : 7-1-2001
Plug and Play Software Device Enumerator
Driver
Description : Plug and Play Software Device Enumerator
Company : Microsoft
Date : 7-1-2001
Microcode Update Device
Driver
Description : Microcode Update Device
Company : Microsoft
Date : 7-1-2001
Microsoft System Management BIOS Driver
Driver
Description : Microsoft System Management BIOS Driver
Company : Microsoft
Date : 7-1-2001
PnP BIOS Extension
Driver
Description : PnP BIOS Extension
Company : Generic
Version : 3.47.0.0
Date : 8-22-2004
File Name : oem5.inf
Computer
ACPI Uniprocessor PC
Driver
Description : ACPI Uniprocessor PC
Company : Microsoft
Version : 5.1.2600.0
Date : 7-1-2001
File Name : hal.inf
Processors
Intel(R) Pentium(R) 4 CPU 2.80GHz
Driver
Description : Intel Processor
Company : Microsoft
Date : 4-1-2004
File Name : cpu.inf
Display adapters
ATI RADEON XPRESS 200 Series
Driver
Description : ATI RADEON XPRESS 200 Series
Company : ATI Technologies Inc.
Version : 8.172.0.0
Date : 8-30-2005
File Name : oem2.inf
Monitors
Plug and Play Monitor
Driver
Description : Plug and Play Monitor
Company : Microsoft
Version : 5.1.2001.0
Date : 6-6-2001
File Name : monitor.inf
IDE ATA/ATAPI controllers
Standard Dual Channel PCI IDE Controller
Driver
Description : Standard Dual Channel PCI IDE Controller
Company : Microsoft
Date : 7-1-2001
File Name : mshdc.inf
Primary IDE Channel
Driver
Description : Primary IDE Channel
Company : Microsoft
Date : 7-1-2001
Secondary IDE Channel
Driver
Description : Secondary IDE Channel
Company : Microsoft
Date : 7-1-2001
Driver
Company : Microsoft
Date : 7-1-2001
Primary IDE Channel
Driver
Company : Microsoft
Date : 7-1-2001
Driver
Company : Microsoft
Date : 7-1-2001
ATI IDE Controller
Driver
Description : ATI IDE Controller
Version : 5.0.0.2
Date : 4-15-2004
File Name : oem0.inf
Primary IDE Channel
Driver
Company : Microsoft
Date : 7-1-2001
Driver
Company : Microsoft
Date : 7-1-2001
Disk drives
ST380211AS
Driver
Description : Disk drive
Company : Microsoft
Date : 7-1-2001
File Name : disk.inf
Universal Serial Bus controllers
Standard OpenHCD USB Host Controller
Driver
Description : Standard OpenHCD USB Host Controller
Company : Microsoft
Date : 7-1-2001
File Name : usbport.inf
USB Root Hub
Driver
Description : USB Root Hub
Company : Microsoft
Date : 7-1-2001
Driver
Company : Microsoft
Date : 7-1-2001
USB Root Hub
Driver
Company : Microsoft
Date : 7-1-2001
Standard Enhanced PCI to USB Host Controller
Driver
Description : Standard Enhanced PCI to USB Host Controller
Company : Microsoft
Date : 6-1-2002
USB Root Hub
Driver
Company : Microsoft
Date : 7-1-2001
DVD/CD-ROM drives
Driver
Description : CD-ROM Drive
Company : Microsoft
Date : 7-1-2001
File Name : cdrom.inf
SONY CD-RW CRX320EE
Driver
Company : Microsoft
Date : 7-1-2001
Generic DVD-ROM SCSI CdRom Device
Driver
Company : Microsoft
Date : 7-1-2001
Sound, video and game controllers
Realtek High Definition Audio
Driver
Description : Realtek High Definition Audio
Company : Realtek Semiconductor Corp.
Version : 5.10.0.5172
Date : 9-23-2005
File Name : oem3.inf
Audio Codecs
Driver
Description : Audio Codecs
Company : Microsoft
Date : 7-1-2001
File Name : wave.inf
Legacy Audio Drivers
Driver
Description : Legacy Audio Drivers
Company : Microsoft
Date : 7-1-2001
Media Control Devices
Driver
Description : Media Control Devices
Company : Microsoft
Date : 7-1-2001
Legacy Video Capture Devices
Driver
Description : Legacy Video Capture Devices
Company : Microsoft
Date : 7-1-2001
Video Codecs
Driver
Description : Video Codecs
Company : Microsoft
Date : 7-1-2001
Microsoft WINMM WDM Audio Compatibility Driver
Driver
Description : Microsoft WINMM WDM Audio Compatibility Driver
Company : Microsoft
Date : 7-1-2001
File Name : wdmaudio.inf
Microsoft Kernel System Audio Device
Driver
Description : Microsoft Kernel System Audio Device
Company : Microsoft
Date : 7-1-2001
Microsoft Kernel Audio Splitter
Driver
Description : Microsoft Kernel Audio Splitter
Company : Microsoft
Date : 7-1-2001
Microsoft Kernel Wave Audio Mixer
Driver
Description : Microsoft Kernel Wave Audio Mixer
Company : Microsoft
Date : 7-1-2001
Network adapters
Realtek RTL8139/810x Family Fast Ethernet NIC
Driver
Description : Realtek RTL8139/810x Family Fast Ethernet NIC
Version : 5.630.824.2005
Date : 9-28-2005
File Name : oem4.inf
WAN Miniport (L2TP)
Driver
Description : WAN Miniport (L2TP)
Company : Microsoft
Date : 7-1-2001
File Name : netrasa.inf
WAN Miniport (IP)
Driver
Description : WAN Miniport (IP)
Company : Microsoft
Date : 7-1-2001
WAN Miniport (PPPOE)
Driver
Description : WAN Miniport (PPPOE)
Company : Microsoft
Date : 7-1-2001
WAN Miniport (PPTP)
Driver
Description : WAN Miniport (PPTP)
Company : Microsoft
Date : 7-1-2001
Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport
Driver
Description : Packet Scheduler Miniport
Company : Microsoft
Date : 7-1-2001
File Name : netpsa.inf
WAN Miniport (IP) - Packet Scheduler Miniport
Driver
Company : Microsoft
Date : 7-1-2001
Direct Parallel
Driver
Description : Direct Parallel
Company : Microsoft
Date : 7-1-2001
Hamachi Network Interface
Driver
Description : Hamachi Network Interface
Company : LogMeIn, Inc.
Version : 6.0.1.0
Date : 4-1-2006
File Name : oem45.inf
Floppy disk controllers
Standard floppy disk controller
Driver
Description : Standard floppy disk controller
Company : Microsoft
Date : 7-1-2001
File Name : fdc.inf
Floppy disk drives
Floppy disk drive
Driver
Description : Floppy disk drive
Company : Microsoft
Date : 7-1-2001
File Name : flpydisk.inf
Ports (COM & LPT)
Communications Port (COM1)
Driver
Description : Communications Port
Company : Microsoft
Date : 7-1-2001
File Name : msports.inf
ECP Printer Port (LPT1)
Driver
Description : ECP Printer Port
Company : Microsoft
Date : 7-1-2001
Mice and other pointing devices
PS/2 Compatible Mouse
Driver
Description : PS/2 Compatible Mouse
Company : Microsoft
Date : 7-1-2001
File Name : msmouse.inf
Keyboards
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Driver
Description : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Company : Microsoft
Date : 7-1-2001
File Name : keyboard.inf
Storage volumes
Generic volume
Driver
Description : Generic volume
Company : Microsoft
Date : 7-1-2001
File Name : volume.inf
Generic volume
Driver
Company : Microsoft
Date : 7-1-2001
Generic volume
Driver
Company : Microsoft
Date : 7-1-2001
Generic volume
Driver
Company : Microsoft
Date : 7-1-2001
Non-Plug and Play Drivers
AFD
Driver
Description
Company
Version
Date
File Name
AVG7 Kernel
Driver
Description
Company
Version
Date
File Name
AVG7 Wrap Driver
Driver
Description
Company
Version
Date
File Name
AVG7 Resident Driver XP
Driver
Description
Company
Version
Date
File Name
AVG Anti-Spyware Clean Driver
Driver
Description
Company
Version
Date
File Name
AVG7 Clean Driver
Driver
Description
Company
Version
Date
File Name
AVG Network Redirector
Driver
Description
Company
Version
Date
File Name
AVG Anti-Spyware Driver
Driver
Description
Company
Version
Date
File Name
Beep
Driver
Description
Company
Version
Date
File Name
dmboot
Driver
Description
Company
Version
Date
File Name
dmload
Driver
Description
Company
Version
Date
File Name
Fips
Driver
Description
Company
Version
Date
File Name
Generic Packet Classifier
Driver
Description
Company
Version
Date
File Name
HTTP
Driver
Description
Company
Version
Date
File Name
IP Network Address Translator
Driver
Description
Company
Version
Date
File Name
IPSEC driver
Driver
Description
Company
Version
Date
File Name
ksecdd
Driver
Description
Company
Version
Date
File Name
mnmdd
Driver
Description
Company
Version
Date
File Name
mountmgr
Driver
Description
Company
Version
Date
File Name
NDIS System Driver
Driver
Description
Company
Version
Date
File Name
Remote Access NDIS TAPI Driver
Driver
Description
Company
Version
Date
File Name
NDIS Usermode I/O Protocol
Driver
Description
Company
Version
Date
File Name
NDProxy
Driver
Description
Company
Version
Date
File Name
NetBios over Tcpip
Driver
Description
Company
Version
Date
File Name
Null
Driver
Description
Company
Version
Date
File Name
PartMgr
Driver
Description
Company
Version
Date
File Name
ParVdm
Driver
Description
Company
Version
Date
File Name
PCTINDIS5 NDIS Protocol Driver
Driver
Description
Company
Version
Date
File Name
Remote Access Auto Connection Driver
Driver
Description
Company
Version
Date
File Name
RDPCDD
Driver
Description
Company
Version
Date
File Name
Secdrv
Driver
Description
Company
Version
Date
File Name
StarForce Protection Environment Driver (version 1.x)
Driver
Description
Company
Version
Date
File Name
StarForce Protection Helper Driver (version 2.x)
Driver
Description
Company
Version
Date
File Name
StarForce Protection Synchronization Driver (version 2.x)
Driver
Description
Company
Version
Date
File Name
StarForce Protection VFS Driver (version 2.x)
Driver
Description
Company
Version
Date
File Name
sptd
Driver
Description
Company
Version
Date
File Name
TCP/IP Protocol Driver
Driver
Description
Company
Version
Date
File Name
VgaSave
Driver
Description
Company
Version
Date
File Name
VolSnap
Driver
Description
Company
Version
Date
File Name
Remote Access IP ARP Driver
Driver
Description
Company
Version
Date
File Name
Windows Socket 2.0 Non-IFS Service Provider Support Environment
Driver
Description
Company
Version
Date
File Name
XPROTECTOR
Driver
Description
Company
Version
Date
File Name
SCSI and RAID controllers
D347PRT SCSI Controller
Driver
Description : SCSI/RAID Host Controller
Company : Microsoft
Date : 7-1-2001
File Name : pnpscsi.inf
Software Information
Description : Nero Home
Version : 1, 7, 11, 0
Company : Nero AG
Description : Nero StartSmart
Version : 3, 7, 1, 0
Company : Nero AG
Description : MSI starter
Version : 1, 6, 13, 0
Company : Nero AG
Description : Nero Burning ROM
Version : 7, 7, 5, 1
Company : Nero AG
Company : Nero AG
Description : Nero SoundTrax
Version : 2, 7, 2, 0
Company : Nero AG
Description : Wave Editor
Version : 3, 7, 2, 1
Company : Nero AG
Description : Nero BackItUp
Version : 2, 7, 3, 2
Company : Nero AG
Description : Cover Designer
Version : 2, 7, 3, 0
Company : Nero AG
Description : Nero PhotoSnap image editor
Version : 1, 2, 0, 19
Company : Nero AG
Description : Nero Photosnap Image Viewer
Company : Nero AG
Description : Nero Recode 2
Version : 2, 4, 5, 0
Company : Nero AG
Description : Nero Vision
Version : 4,9,0,18
Company : Nero AG
Description : Nero ShowTime
Version : 3, 5, 3, 2
Company : Nero AG
Description : Nero MediaHome
Version : 2, 1, 11, 0
Company : Nero AG
Description : Nero ImageDrive
Version : 3.0.0.12
Company : Nero AG
Description : Nero CD - DVD Speed
Version : 4, 7, 0, 2
Company : Nero AG
Description : Nero DriveSpeed
Version : 3, 0, 10, 0
Company : Nero AG
Description : Nero InfoTool
Version : 4, 2, 1, 0
Company : Nero AG
Description : Nero BurnRights Control Panel
Version : 2.1.0.6
Company : Nero AG
Company : Nero AG
Description : Nero Scout Options
Company : Nero AG
Description : Nero Search Advanced
Company : Nero AG
Description : NMBg Monitor
Company : Nero AG
Description : NM First Start
Company : Nero AG
Description : NMIndexingService
Company : Nero AG
Description : NeTsMan
Version : 1, 0, 3, 0
Company : Nero AG
Description : NiReg
Version : 1, 5, 1002, 0
Company : Nero AG
Description : NMTVServer
Company : Nero AG
Description : NMTv Wizard
Company : Nero AG
Description : NMBC Writer
Company : Nero AG
Description : Nero Check
Version : 1, 0, 0, 5
Company : Nero AG
Description : Nero Patent Activation
Version : 7.7.7.0
Company : Nero AG
Description : NMS Transcoder
Company : Nero AG
Description : Nero Online Upgrade
Version : 7.7.7.0
Company : Nero AG
Description : Nero Remote Ctrl Handler
Company : Nero AG
Description : Nero Slide Show
Version : 1, 0, 0, 3
Company : Nero AG
Hardware Information
CPU : Intel(R) Pentium(R) 4 CPU 2.80GHz
Bus Type : PCI Bus
Motherboard : Intel Corporation D101GGC AAD35788-304
s
: Award BIOS for Intel Phoenix - AwardBIOS v6.00PG
Memory : 446 MB
: <Realtek HD Audio output
Driver Information
Driver : Abiosdsk
Description : n/a
Version : n/a
Company : n/a
Driver : abp480n5
Description : n/a
Version : n/a
Company : n/a
Driver : ACPI
Description : ACPI Driver for NT
Version : 5.1.2600.2180 (xpsp_sp2_rtm.040803-215
Company : Microsoft Corporation
Driver : ACPIEC
Description : ACPI Embedded Controller Driver
Version : 5.1.2600.0 (xpclient.010817-114
Driver : adpu160m
Description : n/a
Version : n/a
Company : n/a
Driver : aec
Description : Microsoft Acoustic Echo Canceller
Version : 5.1.2601.2078
Driver : Aha154x
Description : n/a
Version : n/a
Company : n/a
Driver : aic78u2
Description : n/a
Version : n/a
Company : n/a
Driver : aic78xx
Description : n/a
Version : n/a
Company : n/a
Driver : AliIde
Description : n/a
Version : n/a
Company : n/a
Driver : amsint
Description : n/a
Version : n/a
Company : n/a
Driver : asc
Description : n/a
Version : n/a
Company : n/a
Driver : asc3350p
Description : n/a
Version : n/a
Company : n/a
Driver : asc3550
Description : n/a
Version : n/a
Company : n/a
Driver : AsyncMac
Description : MS Remote Access serial network driver
Driver : atapi
Description : IDE/ATAPI Port Driver
Driver : Atdisk
Description : n/a
Version : n/a
Company : n/a
Driver : ati2mtag
Description : ATI Radeon WindowsNT Miniport Driver
Version : 6.14.10.6571
Driver : Atmarpc
Description : IP/ATM Arp Client
Driver : audstub
Description : AudStub Driver
Version : 5.1.2600.0 (XPClient.010817-114
Driver : AVG Anti-Spyware Driver
Description : n/a
Version : n/a
Company : n/a
Driver : Avg7Core
Description : AVG Scanning Engine
Version : 7.5.0.422
Company : GRISOFT, s.r.o.
Driver : Avg7RsW
Description : AVG Resident Shield Unload Helper
Version : 7,0,0,340
Driver : Avg7RsXP
Description : AVG Resident Anti-Virus Shield
Version : 7,1,0,398
Driver : AvgAsCln
Description : AVG7 Clean Driver
Version : 1.0.0.14
Driver : AvgClean
Version : 1.0.0.14
Driver : AvgTdi
Description : AVG Network connection watcher
Version : 7,0,0,346
Driver : cbidf2k
Description : CardBus/PCMCIA IDE Miniport Driver
Driver : cd20xrnt
Description : n/a
Version : n/a
Company : n/a
Driver : Cdaudio
Description : CD-ROM Audio Filter Driver
Driver : Cdfs
Description : CD-ROM File System Driver
Driver : Cdrom
Description : SCSI CD-ROM Driver
Driver : Changer
Description : n/a
Version : n/a
Company : n/a
Driver : CmdIde
Description : n/a
Version : n/a
Company : n/a
Driver : Cpqarray
Description : n/a
Version : n/a
Company : n/a
Driver : d347bus
Version : 3.47.0.0 built by: WinDDK
Company :
Driver : d347prt
Description : SCSI miniport
Company :
Driver : dac960nt
Description : n/a
Version : n/a
Company : n/a
Driver : Disk
Description : PnP Disk Driver
Driver : dmboot
Description : NT Disk Manager Startup Driver
Version : 2600.2180.503.0
Company : Microsoft Corp., Veritas Software
Driver : dmio
Description : NT Disk Manager I/O Driver
Driver : dmload
Version : 2600.0.503.0
Company : Microsoft Corp., Veritas Software.
Driver : DMusic
Description : Microsoft Kernel DLS Synthesizer
Driver : dpti2o
Description : n/a
Version : n/a
Company : n/a
Driver : drmkaud
Description : Microsoft Kernel DRM Audio Descrambler Filter
Driver : Fastfat
Description : Fast FAT File System Driver
Driver : Fdc
Description : Floppy Disk Controller Driver
Driver : Flpydisk
Description : Floppy Driver
Driver : FltMgr
Description : Microsoft Filesystem Filter Manager
Driver : Ftdisk
Description : FT Disk Driver
Driver : Gpc
Description : n/a
Version : n/a
Company : n/a
Driver : hamachi
Description : Hamachi Virtual Network Interface Driver
Version : 6.0.0.0
Driver : HDAudBus
Description : High Definition Audio Bus Driver v1.0a
Version : 5.10.01.5013 built by: WinDDK
Company : Windows (R) Server 2003 DDK provider
Driver : hpn
Description : n/a
Version : n/a
Company : n/a
Driver : HTTP
Description : HTTP Protocol Stack
Driver : i2omgmt
Description : n/a
Version : n/a
Company : n/a
Driver : i2omp
Description : n/a
Version : n/a
Company : n/a
Driver : i8042prt
Description : i8042 Port Driver
Driver : Imapi
Description : IMAPI Kernel Driver
Driver : ini910u
Description : n/a
Version : n/a
Company : n/a
Driver : IntcAzAudAddService
Description : n/a
Version : n/a
Company : n/a
Driver : IntelIde
Description : n/a
Version : n/a
Company : n/a
Driver : intelppm
Description : Processor Device Driver
Driver : Ip6Fw
Description : IPv6 Windows Firewall Driver
Driver : IpFilterDriver
Description : n/a
Version : n/a
Company : n/a
Driver : IpInIp
Description : IP in IP Encapsulation Driver
Driver : IpNat
Description : IP Network Address Translator
Driver : IPSec
Description : IPSec Driver
Driver : IRENUM
Description : Infra-Red Bus Enumerator
Driver : isapnp
Description : PNP ISA Bus Driver
Driver : kmixer
Description : Kernel Mode Audio Mixer
Driver : lbrtfdc
Description : n/a
Version : n/a
Company : n/a
Driver : Modem
Description : Modem Device Driver
Driver : mraid35x
Description : n/a
Version : n/a
Company : n/a
Driver : MRxDAV
Description : Windows NT WebDav Minirdr
Driver : MSKSSRV
Description : MS KS Server
Version : 5.3.2600.2180 (xpsp_sp2_rtm.040803-215
Driver : MSPCLOCK
Description : MS Proxy Clock
Driver : MSPQM
Description : MS Proxy Quality Manager
Driver : mssmbios
Description : System Management BIOS Driver
Driver : NdisTapi
Description : NDIS 3.0 connection wrapper driver
Driver : Ndisuio
Description : NDIS User mode I/O Driver
Driver : NdisWan
Description : MS PPP Framing Driver (Strong Encryption)
Driver : Nokia USB Generic
Description : n/a
Version : n/a
Company : n/a
Driver : Nokia USB Modem
Description : n/a
Version : n/a
Company : n/a
Driver : Nokia USB Phone Parent
Description : n/a
Version : n/a
Company : n/a
Driver : Npfs
Description : NPFS Driver
Driver : Ntfs
Description : NT File System Driver
Driver : NwlnkFlt
Description : NWLINK2 Traffic Filter Driver
Driver : NwlnkFwd
Description : NWLINK2 Forwarder Driver
Driver : Parport
Description : Parallel Port Driver
Driver : PartMgr
Description : Partition Manager
Driver : ParVdm
Description : VDM Parallel Driver
Driver : PCI
Description : NT Plug and Play PCI Enumerator
Driver : PCIDump
Description : n/a
Version : n/a
Company : n/a
Driver : PCIIde
Description : Generic PCI IDE Bus Driver
Driver : Pcmcia
Description : PCMCIA Bus Driver
Driver : pcouffin
Description : low level access layer for CD/DVD/BD devices
Version : 1.37
Company : VSO Software
Driver : PCTINDIS5
Description : n/a
Version : n/a
Company : n/a
Driver : PDCOMP
Description : n/a
Version : n/a
Company : n/a
Driver : PDFRAME
Description : n/a
Version : n/a
Company : n/a
Driver : PDRELI
Description : n/a
Version : n/a
Company : n/a
Driver : PDRFRAME
Description : n/a
Version : n/a
Company : n/a
Driver : perc2
Description : n/a
Version : n/a
Company : n/a
Driver : perc2hib
Description : n/a
Version : n/a
Company : n/a
Driver : PptpMiniport
Description : n/a
Version : n/a
Company : n/a
Driver : PSched
Description : MS QoS Packet Scheduler
Driver : Ptilink
Description : Parallel Technologies DirectParallel IO Library
Version : 1.10 (XPClient.010817-114
Company : Parallel Technologies, Inc.
Driver : PxHelp20
Description : Px Engine Device Driver for Windows 2000/XP
Version : 3.00.11B
Company : Sonic Solutions
Driver : ql1080
Description : n/a
Version : n/a
Company : n/a
Driver : Ql10wnt
Description : n/a
Version : n/a
Company : n/a
Driver : ql12160
Description : n/a
Version : n/a
Company : n/a
Driver : ql1240
Description : n/a
Version : n/a
Company : n/a
Driver : ql1280
Description : n/a
Version : n/a
Company : n/a
Driver : Rasl2tp
Description : RAS L2TP mini-port/call-manager driver
Driver : RasPppoe
Description : RAS PPPoE mini-port/call-manager driver
Driver : Raspti
Description : PTI DirectParallel(R) mini-port/call-manager driver
Driver : Rdbss
Description : Redirected Drive Buffering SubSystem Driver
Version : 5.1.2600.2902 (xpsp_sp2_gdr.060505-0036)
Driver : RDPCDD
Description : RDP Miniport
Driver : rdpdr
Description : Microsoft RDP Device redirector
Driver : RDPWD
Description : RDP Terminal Stack Driver (US/Canada Only, Not for Export)
Driver : redbook
Description : Redbook Audio Filter Driver
Driver : RTL8023xp
Description : n/a
Version : n/a
Company : n/a
Driver : rtl8139
Description : Realtek RTL8139 NDIS 5.0 Driver
Version : 5.398.613.2003 built by: WinDDK
Company : Realtek Semiconductor Corporation
Driver : secdir
Description : n/a
Version : n/a
Company : n/a
Driver : Secdrv
Description : Macrovision SECURITY Driver
Version : 3.22.000
Company : Macrovision Corporation, Macrovision Europe Limited, and Macrovision Japan and Asia K.K.
Driver : serenum
Description : Serial Port Enumerator
Driver : Serial
Description : Serial Device Driver
Driver : sfdrv01
Description : StarForce Protection Environment Driver
Version : 1.37
Company : Protection Technology
Driver : sfhlp02
Description : StarForce Protection Helper Driver
Version : 2.3
Driver : Sfloppy
Description : SCSI Floppy Driver
Driver : sfsync02
Description : StarForce Protection Synchronization Driver
Version : 2.12
Driver : sfvfs02
Description : StarForce Protection VFS Driver
Version : 2.12
Driver : Simbad
Description : n/a
Version : n/a
Company : n/a
Driver : SMBios
Description : Intel(R) System Management BIOS Driver
Version : 1.0.0.14
Driver : Sparrow
Description : n/a
Version : n/a
Company : n/a
Driver : splitter
Driver : sptd
Description : n/a
Version : n/a
Company : n/a
Driver : sr
Description : System Restore Filesystem Filter Driver
Driver : Srv
Description : Server driver
Driver : swenum
Driver : swmidi
Description : Microsoft GS Wavetable Synthesizer
Driver : symc810
Description : n/a
Version : n/a
Company : n/a
Driver : symc8xx
Description : n/a
Version : n/a
Company : n/a
Driver : sym_hi
Description : n/a
Version : n/a
Company : n/a
Driver : sym_u3
Description : n/a
Version : n/a
Company : n/a
Driver : sysaudio
Description : System Audio WDM Filter
Driver : Tcpip
Description : TCP/IP Protocol Driver
Driver : TDPIPE
Description : Named Pipe Transport Driver
Driver : TDTCP
Description : TCP Transport Driver
Driver : TermDD
Description : Terminal Server Driver
Driver : TosIde
Description : n/a
Version : n/a
Company : n/a
Driver : Udfs
Description : UDF File System Driver
Driver : ultra
Description : n/a
Version : n/a
Company : n/a
Driver : Update
Description : Update Driver
Driver : usbehci
Description : EHCI eUSB Miniport Driver
Driver : usbhub
Description : Default Hub Driver for USB
Driver : usbohci
Description : OHCI USB Miniport Driver
Driver : USBSTOR
Description : USB Mass Storage Class Driver
Driver : VgaSave
Description : n/a
Version : n/a
Company : n/a
Driver : ViaIde
Description : n/a
Version : n/a
Company : n/a
Driver : VolSnap
Description : Volume Shadow Copy Driver
Driver : w550bus
Description : Sony Ericsson W550 Driver
Version : V4.34
Company : MCCI
Driver : w550mdfl
Description : Sony Ericsson W550 USB WMC Modem Filter Driver
Version : V4.34
Company : MCCI
Driver : w550mdm
Description : Sony Ericsson W550 USB WMC Modem WDM Driver
Version : V4.34
Company : MCCI
Driver : w550mgmt
Description : Sony Ericsson W550 USB WMC Device Management Driver
Version : V4.34
Company : MCCI
Driver : w550obex
Description : Sony Ericsson W550 USB WMC OBEX Interface Device Driver
Version : V4.34
Company : MCCI
Driver : Wanarp
Description : MS Remote Access and Routing ARP Driver
Driver : WDICA
Description : n/a
Version : n/a
Company : n/a
Driver : wdmaud
Description : MMSYSTEM Wave/Midi API mapper
Driver : WS2IFSL
Description : Winsock2 IFS Layer
Driver : WudfPf
Description : Windows Driver Foundation - User-mode Driver Framework Platform Driver
Version : 6.0.5716.32 (winmain(wmbla).060928-1756)
Driver : WudfRd
Description : Windows Driver Foundation - User-mode Driver Framework Reflector
Driver : XPROTECTOR
Description : n/a
Version : n/a
Company : n/a
Driver : msvcrt.dll
Version : 7.0.2600.2180 (xpsp_sp2_rtm.040803-215
Driver : msvcirt.dll
Driver : mfc42.dll
Version : 6.02.4131.0
Driver : msvcp60.dll
Version : 6.02.3104.0
Driver : Msvcr70.dll
Version : 7.00.9466.0
Driver : ole32.dll
Version : 5.1.2600.2665 (xpsp_sp2_gdr.050427-1553)
Driver : olepro32.dll
Driver : oledlg.dll
Version : 1.0 (XPClient.010817-114
Driver : advapi32.dll
Driver : comctl32.dll
Version : 5.82 (xpsp_sp2_rtm.040803-215
Driver : setupapi.dll
Driver : background.png
Version : n/a
Driver : nero_logo.png
Version : n/a
Driver : pause hot.png
Version : n/a
Driver : pause pushed.png
Version : n/a
Driver : pause.png
Version : n/a
Driver : play hot.png
Version : n/a
Driver : play pushed.png
Version : n/a
Driver : play.png
Version : n/a
Driver : skin.png
Version : n/a
Driver : skin.xml
Version : n/a
Driver : slider button hot.png
Version : n/a
Driver : slider button pushed.png
Version : n/a
Driver : slider button.png
Version : n/a
Driver : slider.png
Version : n/a
Driver : slider_bkgnd.png
Version : n/a
Driver : slider_fill.png
Version : n/a
Driver : sound_toggle.png
Version : n/a
Driver : sound_toggle_hot.png
Version : n/a
Driver : sound_toggle_pushed.png
Version : n/a
Driver : stop hot.png
Version : n/a
Driver : stop pushed.png
Version : n/a
Driver : stop.png
Version : n/a
Version : n/a
Version : n/a
Driver : pause.png
Version : n/a
Version : n/a
Version : n/a
Driver : play.png
Version : n/a
Driver : skin.png
Version : n/a
Driver : skin.xml
Version : n/a
Driver : skinalt.png
Version : n/a
Version : n/a
Version : n/a
Version : n/a
Driver : slider.png
Version : n/a
Version : n/a
Version : n/a
Version : n/a
Version : n/a
Driver : stop.png
Version : n/a
Driver : mfc71u.dll
Version : 7.10.3077.0
Driver : msvcp71.dll
Driver : msvcr71.dll
Version : 7.10.3052.4
Driver : NeroScout_Eng.chm
Version : n/a
Driver : MediaLibraryNSE.dll
Driver : NeroPreview.dll
Driver : NeroSearchBar.dll
Driver : NMDataServices.dll
Driver : BCGCBPRO800u.dll
Version : 8, 00, 0, 0
Driver : log4cxx.dll
Version : 1, 0, 0, 0
Driver : NeroSearchTray.dll
Driver : NeroSearchTrayHook.dll
Driver : NMAudioCDContentHandler.dll
Driver : NMCoFoundation.dll
Driver : NMSQLDB.dll
Driver : MFC71.dll
Driver : NMFullTextExtraction.dll
Driver : NMHDirServices.dll
Driver : NMIndexingServicePS.dll
Driver : NMIndexStoreSvrPS.dll
Driver : NMInternetServices.dll
Driver : NMLogCxx.dll
Driver : NMPluginBase.dll
Driver : NMSearch.dll
Driver : NMSearchPluginMediaLibrary.dll
Driver : NMSearchPluginSimilarImages.dll
Driver : NMSearchPluginWeb.dll
Driver : NMThumbnailIconsGen.dll
Driver : NMUPnPBrowser.dll
Driver : NMUPnPServices.dll
Driver : NMUPnPServicesLibPS.dll
Driver : GCCapture.ax
Version : 4,9,0,18
Driver : GCCore.dll
Version : 4,9,0,18
Driver : GCHW.dll
Version : 4,6,0,10
Driver : NeAcEnc.dll
Version : 4,6,15,0
Driver : ndaudio.dll
Version : 4, 6, 15, 0
Driver : BDEngine.dll
Driver : em2v.dll
Version : 4,6,15,0
Driver : HDDVDEngine.dll
Driver : NeEm2a.dll
Version : 4,6,15,0
Driver : NeEm2v.dll
Version : 4,6,15,0
Driver : NeroIPP.dll
Version : 4,6,15,0
Driver : NeroMediaCon.dll
Driver : NeGuideStore.dll
Version : 1, 3, 0, 0
Driver : NeGuideStoreLoader.dll
Driver : NeVcr.dll
Driver : uNeroMediaCon.dll
Driver : CaptureAPI.dll
Driver : NMDefaultDRMDialogs.dll
Driver : NMDvdContentHandler.dll
Driver : NMFileContentHandler.dll
Driver : NMPFContentHandler.dll
Version : 1, 7, 9, 0
Driver : NMPlaybackComponent.dll
Driver : NMSlideShow.dll
Driver : NMSSContentHandler.dll
Driver : NMSSEffects.dll
Driver : NMSVCDContentHandler.dll
Driver : NMTVConfigdvbc.xml
Version : n/a
Driver : NMTVConfigdvbs.xml
Version : n/a
Driver : NMTVConfigdvbt.xml
Version : n/a
Driver : NMTVEpgPluginXmlTv.dll
Driver : NMTVServices.dll
Driver : NMTVStreamContentHandler.dll
Driver : NMVisualizerNas.dll
Driver : BCGCBPRO860un71.dll
Version : 8, 60, 0, 0
Driver : BCGPOleAcc.dll
Version : 8, 50, 0, 0
Driver : NeroFileDialogCF.dll
Driver : NeroFileDialog.dll
Driver : NeroFileDialogIDLPS.dll
Driver : NeroFileDialogVista.dll
Driver : NeroSearch.dll
Driver : NMBC.dll
Driver : NMBCInterfacePS.dll
Driver : NeroDigitalExt.dll
Version : 2, 0, 0, 8
Driver : NeroStarter.dll
Version : 2,1,23,0
Driver : NMScriptingObject.dll
Driver : NMUIEngine.dll
Driver : NMUIGDIPlus.dll
Driver : NMUIVKStandard.dll
Driver : AdvrCntr2.dll
Version : 7,7,0, 10200
Driver : NEROINST.DB
Version : n/a
Driver : ShellManager.dll
Version : 7.7.7.0
Driver : NeroCBUI.dll
Version : 1, 7, 0, 7
Driver : DriveLocker.dll
Version : 1, 0, 0, 18
Driver : BCGCBPRO730u.dll
Version : 7, 30, 0, 0
Driver : MPVInterface.dll
Version : 2.0.0.0
Driver : lgpl.txt
Version : n/a
Driver : libxml_license.txt
Version : n/a
Driver : lzma.txt
Version : n/a
Driver : zlib_license.txt
Version : n/a
Driver : cximage.dll
Version : 5, 9, 9, c
Driver : DynamicDialog.dll
Version : 1, 7, 5, 0
Driver : iconv.dll
Version : 1.9
Driver : lib3ds_dll.dll
Driver : libxml2.dll
Version : 2, 6, 23, 0
Driver : atl71.dll
Driver : Nero3DMenuEffects.dll
Driver : NSG_dxFilter.dll
Driver : NSGResources.dll
Driver : zlib1.dll
Version : 1.2.3
Driver : NMTTranscoder.dll
Driver : NMTTranscoderPS.dll
Driver : ROLLBACK.DB
Version : n/a
Driver : neroapl.dll
Version : 4,6,15,0
Driver : AReadyLB_Nero.dll
Version : 5, 0, 0, 15
Driver : HMNavigator.ax
Version : 4,6,15,0
Driver : NDParser.ax
Version : 4,6,15,0
Driver : ndvddisc.dll
Version : 4,6,15,
Driver : NeAMR.dll
Version : 4,6,15,0
Driver : NeAudCD.ax
Version : 4,6,15,0
Driver : NeAudible.ax
Version : 4,6,15,0
Driver : NeAudio2.ax
Version : 4,6,15,0
Driver : NeAVSync.ax
Version : 4,6,15,
Driver : NeBDGraphic.ax
Version : 4,6,15,0
Driver : NeBDThumbnail.ax
Version : 4,6,15,0
Driver : NeCapture.ax
Version : 4,6,15,0
Driver : NeDeinterlace.ax
Version : 4,6,15,
Driver : NeDiscManager.dll
Version : 4,6,15,0
Driver : NeDVD.ax
Version : 4,6,15,0
Driver : NeDVSplitter.ax
Version : 4,6,15,0
Driver : NeEacDec.dll
Version : 4,6,15,0
Driver : NeFileSourceAsync.ax
Version : 4,6,15,0
Driver : NeFileSrc.ax
Version : 4,6,15,0
Driver : NeFSource.ax
Version : 4,6,15,0
Driver : NeMlpDec.dll
Version : 4,6,15,0
Driver : NeMp3Encoder.ax
Version : 4,6,15,0
Driver : NeMP4Splitter.ax
Version : 4,6,15,0
Driver : NeNDAud.ax
Version : 4,6,15,0
Driver : NeNDGui.dll
Version : 4,6,15,0
Driver : NeNDMux.ax
Version : 4,6,15,0
Driver : NeNDVid.ax
Version : 4,6,15,0
Driver : NeOggSplitter.ax
Version : 4,6,15,0
Driver : NeOverlayMixer.ax
Version : 4,6,15,0
Driver : NePhotoSource.ax
Version : 4,6,15,0
Driver : NePSMuxer.ax
Version : n/a
Driver : NeQTDec.ax
Version : 4,6,15,0
Driver : NeRender.ax
Version : 4,6,15,0
Driver : NeResize.ax
Version : 4,6,15,
Driver : NeroFormatConv.ax
Version : 4,6,15,0
Driver : NeroVideoProc.ax
Version : 4,6,15,0
Driver : NeSBE.ax
Version : 4,6,15,0
Driver : atl71.dll
Driver : NeSceneDetector.ax
Version : 4,6,15,0
Driver : NeSoundProc.ax
Version : 4,6,15,0
Driver : NeSoundSwitch.ax
Version : 4,6,15,0
Driver : NeSplitter.ax
Version : 4,6,15,0
Driver : NeSubpicture.ax
Version : 4,6,15,0
Driver : NeSubtitle.ax
Version : 4,6,15,0
Driver : NeVCD.ax
Version : 4,6,15,0
Driver : NeVCR.ax
Version : 4,6,15,0
Driver : NeVideoAnalyzer.ax
Version : 4,6,15,0
Driver : NeVideo.ax
Version : 4,6,15,0
Driver : NeVideoHD.ax
Version : 4,6,15,0
Driver : NeVideoRenderer.ax
Version : 4,6,15,0
Driver : MFC71.dll
Driver : NeFTC.ax
Driver : NeSampleQueue.ax
Driver : NeStreamControl.ax
Driver : Afterglow.nvp
Version : n/a
Driver : Alien Funk Too.nvp
Version : n/a
Driver : Alien Funk.nvp
Version : n/a
Driver : Black Hole.nvp
Version : n/a
Driver : Blobz.nvp
Version : n/a
Driver : Bouncing Betty.nvp
Version : n/a
Driver : Chaos.nvp
Version : n/a
Driver : Circumvent.nvp
Version : n/a
Driver : ColorSpray.nvp
Version : n/a
Driver : Crunch.nvp
Version : n/a
Driver : Dances with sprites.nvp
Version : n/a
Driver : Dancing Flower.nvp
Version : n/a
Driver : Deep Dive.nvp
Version : n/a
Driver : Drunk.nvp
Version : n/a
Driver : Evil Germz.nvp
Version : n/a
Driver : Explosion.nvp
Version : n/a
Driver : Flash.nvp
Version : n/a
Driver : Floor.nvp
Version : n/a
Driver : Fuzzy.nvp
Version : n/a
Driver : Groovy Plasma.nvp
Version : n/a
Driver : Hotlines.nvp
Version : n/a
Driver : Hypnotic.nvp
Version : n/a
Driver : Ieltjes Carnaval.nvp
Version : n/a
Driver : Ieltjes Thing 2.nvp
Version : n/a
Driver : Ieltjes Thing.nvp
Version : n/a
Driver : In and Out.nvp
Version : n/a
Driver : Inside.nvp
Version : n/a
Driver : Insufficient Dictionary.nvp
Version : n/a
Driver : Into the Deep.nvp
Version : n/a
Driver : Jelly Wormz.nvp
Version : n/a
Driver : Kaleidoscope.nvp
Version : n/a
Driver : Landscape.nvp
Version : n/a
Driver : Line Art.nvp
Version : n/a
Driver : Liquid.nvp
Version : n/a
Driver : Mars.nvp
Version : n/a
Driver : Microscope.nvp
Version : n/a
Driver : MindTwizt.nvp
Version : n/a
Driver : MJ Past and Present.nvp
Version : n/a
Driver : Need Sunglassez.nvp
Version : n/a
Driver : New Preset.nvp
Version : n/a
Driver : Nice.nvp
Version : n/a
Driver : Owww.nvp
Version : n/a
Driver : Paddo Tango.nvp
Version : n/a
Driver : Pentium.nvp
Version : n/a
Driver : Perspective Tunnel.nvp
Version : n/a
Driver : Planar.nvp
Version : n/a
Driver : Plant.nvp
Version : n/a
Driver : Plasma.nvp
Version : n/a
Driver : Plumeau.nvp
Version : n/a
Driver : PsychoZoom.nvp
Version : n/a
Driver : Quantum Tunnel.nvp
Version : n/a
Driver : RenderExample1.nvp
Version : n/a
Driver : RenderExample2.nvp
Version : n/a
Driver : RenderExample3.nvp
Version : n/a
Driver : Ring.nvp
Version : n/a
Driver : Shadows.nvp
Version : n/a
Driver : Shining Star.nvp
Version : n/a
Driver : Shortcut.nvp
Version : n/a
Driver : Slime.nvp
Version : n/a
Driver : Smudge.nvp
Version : n/a
Driver : Spacy.nvp
Version : n/a
Driver : SpiderRag.nvp
Version : n/a
Driver : Spin Art.nvp
Version : n/a
Driver : Spring.nvp
Version : n/a
Driver : SpriteScope.nvp
Version : n/a
Driver : Spyrodelic.nvp
Version : n/a
Driver : Squares.nvp
Version : n/a
Driver : Stairways.nvp
Version : n/a
Driver : Starfield.nvp
Version : n/a
Driver : Symmetry to the point.nvp
Version : n/a
Driver : The Black Lotus.nvp
Version : n/a
Driver : Torus.nvp
Version : n/a
Driver : Tri-act.nvp
Version : n/a
Driver : Tubes.nvp
Version : n/a
Driver : Tunnel.nvp
Version : n/a
Driver : Unlimited Objects.nvp
Version : n/a
Driver : Vaagheid Galore.nvp
Version : n/a
Driver : Waterfall.nvp
Version : n/a
Driver : WaterMorph.nvp
Version : n/a
Driver : Wormhole.nvp
Version : n/a
Driver : Xyber.nvp
Version : n/a
Driver : Zoomer.nvp
Version : n/a
Driver : fx1.nvl
Version : n/a
Driver : languages.nvl
Version : n/a
Driver : NasEditor.nvl
Version : n/a
Driver : vis_nas.dll
Version : 1, 1, 1, 254
Driver : NeroRcPluginAti.dll
Driver : NeroRcPluginHauppauge.dll
Driver : NeroAti.dl_
Driver : NeroRemoteCtrlInterfaces.dll
Driver : NeroRcPluginMCE.dll
Driver : NeroAti.dll
Driver : aacenc32.dll
Version : 4,6,15,0
Driver : Aiff.dll
Version : 2,1,23,0
Driver : lame_enc.dll
Version : 3, 96, 1, 0
Driver : mp3PP.dll
Version : 2,1,23,0
Driver : mp3PRO.dll
Version : 2,1,23,0
Driver : mp3PRO_dmo.dll
Version : 2,1,23,0
Driver : mp3PRO_hlp.dll
Version : 2,1,23,0
Driver : ogg.dll
Version : 2,1,23,0
Driver : Wav.dll
Version : 2,1,23,0
Version : 5, 0, 0, 18
Driver : Audible.dll
Version : 2,1,23,0
Driver : MFC71.dll
Driver : NeroDigital.dll
Version : 2,1,23,0
Driver : AC3.dll
Version : 2,1,23,0
Driver : DefConvertor.dll
Version : 2,1,23,0
Driver : MSAxp.dll
Version : 2,1,23,0
Driver : msa.dll
Version : 2,1,23,0
Driver : gdiplus.DLL
Version : 5.1.3102.1360 (xpsp2.040109-1800)
Driver : NeroProductSetup_Eng.chm
Version : n/a
Driver : APATCH.DLL
Version : 1.20.1210
Driver :
Version : 1, 63.00.11B
Driver : unrar.dll
Version : n/a
Driver : Burning ROM.ico
Version : n/a
Driver : BackItUp.ico
Version : n/a
Driver : DVDEngine.dll
Description : DVDEngine
Version : 4, 9, 0, 12
Company : Nero AG
Lower Filters
Driver : PxHelp20
Version : 3.00.11B
Upper Filters
Driver
Description : n/a
Version : n/a
Company : n/a
Video Codecs
Cinepak Codec by Radius : 1.10.0.11
Intel 4|2|0 Video V2.50 : 5.1.2600.2180
Intel Indeo(R) Video R3.2
Intel Indeo® Video 4.5 : 4.51.16.03
Intel IYUV codec : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
Microsoft RLE : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
Microsoft Video 1 : 5.1.2600.0 (xpclient.010817-1148)
Microsoft YUV : 5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)
Toshiba YUV Codec : 5.1.2600.0 (XPClient.010817-1148)
Microsoft H.263 Video Codec : 5.1.2600.2180
Microsoft H.261 Video Codec : 5.1.2600.2180
Indeo® video 5.10 : R.5.10.15.2.55
XviD MPEG-4 Codec
Audio Codecs
Microsoft IMA ADPCM CODEC : 4.00.0.0
Microsoft ADPCM CODEC : 4.00.0.0
Microsoft CCITT G.711 A-Law and u-Law CODEC : 4.00.0.0
Microsoft GSM 6.10 Audio CODEC : 4.00.0.0
DSP Group TrueSpeech(TM) Software CODEC : 1.00.0.0
Microsoft G.723.1 CODEC : 1.02.0.1
Windows Media Audio : 4.02.0.0
Sipro Lab Telecom ACELP.net audio codec : 3.02.0.0
Indeo® audio software : 2.05.0.53
Fraunhofer IIS MPEG Layer-3 Codec (advanced) : 1.09.1.49
Fraunhofer IIS MPEG Layer-3 Codec (professional) : 3.04.0.0
Microsoft PCM Converter : 5.00.0.0
Installed OS Patches
(Q810090) USB Update : Yes
(Q329112) Multi-Border DVD with More Than 4 GB of Data Not Readable Past First Border : Yes
(Q812415) Problems with Multiple ATA devices : No
(Q322359) Intelide.sys Is Not Used on Computers with ICH4 or ICH5 : No
(Q320174) IMAPI Update - CDs recorded have missing files or errors : Yes
(Q311542) Devices May not power up properly when resuming from standby : Yes
(Q327086) Data Added to Removable Media During Hibernation May Be Lost When You Resume Windows XP : Yes
(Q308374) Ricoh 1394 Controller May Not Work with Windows XP : No
(Q314634) Windows XP Does Not Detect Your New USB Device : Yes
(Q822603) USB 1.1 and USB 2.0 update : No
(Q323507) Your IEEE 1394 or USB CD-ROM or DVD-ROM Drive May Not Be Recognized in Windows XP : No
(Q815834) 'Code 28' Error Message and a Yellow Exclamation Mark Next to a USB Device in Device Manager After Your Computer Resumes from Hibernation : No
(Q316575) Problems When You Swap a CD-ROM During Hibernation in Windows XP : No
(Q811789) Surprise Removal of 1394 Device Can Cause Bluescreen Error : No
(Q323322) Cannot Use Sony VAIO PCG-C1MRX Internal Camera with Windows Messenger After You Apply Q316397 : No
gau_pppu is offline
Old 09-04-2007, 10:34 AM   #9 (permalink)
hey buddy....
once restall operating system...
it will solve the problem....
sreenivasj is offline
DVD writing problem..... Ambar Hardware Q&A 7 05-04-2007 09:00 AM
Problem writing DVD zegulas QnA (read only) 7 12-09-2006 11:34 AM
DVD writing Problem Him007 QnA (read only) 1 04-02-2006 02:59 PM
CD Writing problem chitvan QnA (read only) 16 11-01-2006 12:56 AM
DVD Writing problem !! hittheswitch QnA (read only) 1 16-08-2005 06:14 AM
- by gforz
