Old 08-04-2007, 06:51 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question How to Install Kaspersky after Mcafee (Problem Installing).............?
My friend have 2 PC's running WinXP_SP2
which has Mcafee Security Suite Installed in it
I wanted to Install Kaspersky Internet Security(KIS), so i Uninstall Mcafee Antivirus & than Mcafee Security Suite
Than i tried to install KIS in it but it says error "remove Mcafee Bonus Pack" & when i see in add remove programme i cant find any Mcafee Product
Than I manually deleted all the Files & Folders from that drive Named Mcafee & all the entrie of Mcafee from registry
but still it says the same error
Now in the 1st PC not a Single file is in the Name of Mcafee than how can the Product still in the PC
Now I Unistall both Mcafee Antivirus & Security Centre from other PC & got the same error
Pls help me tell me how can I install Kaspersky Internet Security
satyamy is offline
Old 08-04-2007, 07:17 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: How to Install Kaspersky after Mcafee (Problem Installing).............?
run CCleaner
& then delete KIS's temp. folder (named kis6) & then run the installer.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 10-04-2007, 01:45 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
Question Re: How to Install Kaspersky after Mcafee (Problem Installing).............?
its not working after CCleaner also
image attached
satyamy is offline
Old 10-04-2007, 08:13 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
reinstall mcafee. reboot. use McAfee Uninstaller. reboot. use ccleaner and manually search for mcafee files/folders on the disk and delete them; do the same in registry using find/findnext.
reboot. now hope kis installs !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 10-04-2007, 09:19 PM   #5 (permalink)
harikatt's Avatar
i would like to say is,, just make install the mcafee first with all full installation,, then in the second reboot,, u uninstall mcafeee everything,, ,, try this if works,, uninstall
then u can try kaspersky
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
Old 10-04-2007, 10:19 PM   #6 (permalink)
Torrent Lover :)
akshaykapoor_3's Avatar
@satyamy
yeh u r rite buddy...dis thing doesnt wrk out...eve i faced dis "bonus pack prob"
tried evrythng possbl bt cudnt get this working
akshaykapoor_3 is offline
Old 10-04-2007, 11:46 PM   #7 (permalink)
keep_it_rl's Avatar
dude goggle for mcafee uninstall tool......it is goin to clean each an evrything related to mcafee and thn u ll b e able to install kaspersky......
keep_it_rl is offline
Old 11-04-2007, 12:38 PM   #8 (permalink)
Alive Again...
satyamy's Avatar
thanks friends
I will try everything you said
& ya thanks @ s18000rpm
in my second PC i tried ccleaner & remove Mcafee Bonus Pack from ccleaner & after this kaspersky installed sucessfully
But in my 1st PC I manually deleted all the files & folders & registry entries related to mcafee but it didnt solve the prob
& ccleaner is also not solving in My 1st PC
I will try rest of the options for this
satyamy is offline
Old 11-04-2007, 10:02 PM   #9 (permalink)
anandk's Avatar
try deleting the follwoing registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall\MSC
Microsoft® MVP
anandk is offline
Old 12-04-2007, 01:08 PM   #10 (permalink)
Alive Again...
satyamy's Avatar
thanks
will try & tell you the result
satyamy is offline
Problem with installing Mcafee CadCrazy Software Q&A 2 30-12-2006 10:33 AM
Install Kaspersky with ZoneAlarm Akshay Software Q&A 10 21-05-2006 12:51 PM
How to install win 98 after installing win xp sidds020 Software Q&A 2 25-03-2006 10:56 AM
who to install xp without installing Win98 harshagarwal Software Q&A 20 17-06-2005 05:38 AM
McAfee problem technovice QnA (read only) 2 21-03-2005 08:40 PM
- by Niilesh
- by chris
- by gforz
