Old 03-04-2007, 08:26 PM   #1 (permalink)
Default a help on video capture
Hi
I need to capture some videos may be in lower bit rate for reduced file size and want to play it back..( in out thru a breakout box like pinnacle ) as video out to record in VTR or so..
which capture card is better..input may be Analog/SDI..output too...
i need to edit captured clips..
is it possible to make a playlist of all clips and play continuously for 6 hours..
P IV processor..SATA HDD..available..Motherboard 915..
RAM now 512 but can enhance it..
Any other requirements...pl help me in building a system..
Capture card + software budget 30 to 40K..
GuruBalaji
gurubalaji is offline
Old 03-04-2007, 10:39 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: a help on video capture
Your budget is high enough for getting a good capture card. Choose from a wide range of Pinnacle Capture cards. Most of them also provide T.V. Tuner too. They are available from Rs.3000/- to Rs. 10000/-. RAM of 512 MB is good enough for Video capture.
There are many Video editors available. Simplest would be Windows Movie Maker. Amoung the paid versions, Ulead Video Studio adds a professional touch to the movie.
Kiran Kumar R
Kiran.dks is offline
Old 03-04-2007, 11:09 PM   #3 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Smile Re: a help on video capture
I will suggest Look Good CARDs FROM COMPRO
THEY ARE BEST IN THE BUSINESS.
Orionz is offline
Old 04-04-2007, 11:45 PM   #4 (permalink)
www.indianangler.com
saikibryan's Avatar
i agree...compro is da best
regards
when the going gets tough, the tough go.....fishing!!!
saikibryan is offline
The Best possible TV / Video Capture Card ..:: Free Radical ::.. Hardware Q&A 4 05-03-2007 12:24 AM
video capture using usb in sony handycam shivi4 Cameras and camcorders 18 16-07-2006 03:36 PM
Video Capture problem. Plz Help. Max_Power Software Q&A 2 20-01-2006 09:37 PM
Video Capture avik_chat Software Q&A 10 16-01-2006 11:26 PM
How to capture online video? geek_rohit Software Q&A 5 10-01-2005 02:13 PM
- by Niilesh
- by chris
- by gforz
