Old 03-04-2007, 12:32 AM   #1 (permalink)
pro
pro's Avatar
Unhappy Accidently installed two WinXPs what to do?
hi all,
i ran winXP setup to repair my current xp installation. accidently i made CD drive as 1st boot device before installing and forgot ot turn it off. now after copying files it restarted and installed 2nd copy in d drive then restarted and installed partial 3rd copy in 3rd e drive as i had sensed my mistake. this e drive is a seperate slave hard disk partition (which used to be d drive earlier)
now HOW CANi remove newer 2nd installation from my pc? i see 3 choices in boot menu. i have erased files in partial 3rd installation.
also
i fear if i remove my 2nd harddisk and format primary for installing fresh XP it might become un recognised....is it possible?
i am feeling very bad. help me....
everything starts with a zero and ends in one.
pro is offline
Old 03-04-2007, 01:08 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Accidently installed two WinXPs what to do?
just Go to start, run, type c:\boot.ini edit the file manually to delete the extra installations lines.. just Keep the 1st line,
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 03-04-2007, 04:02 PM   #3 (permalink)
pro
pro's Avatar
so that will do..... ok i will try and let you know tomorrow
thanks a lot...
pro is offline
Old 04-04-2007, 12:40 PM   #4 (permalink)
digiFriend's Avatar
after editing "boot.ini" also see that you remove all files of windows from D: and E: drive including hidden files like "pagefile" and "hiberfil"
you never know what you can do until you try
digiFriend is offline
Old 04-04-2007, 10:45 PM   #5 (permalink)
pro
pro's Avatar
yes i have seen those two files on mainc drive but for unknown reason they are not present in other drives.... for precaution i have made my original xp to default boot OS by editing boot.ini using msconfig. i have moved it to top position and rest of the choices to downward positions.
pro is offline
Old 05-04-2007, 12:16 PM   #6 (permalink)
digiFriend's Avatar
"pagefile" is virtual memory
"hiberfil" is needed for hibernation.
as you might have not started your OS of D: drive they might not have been created in D:
(if you are not using "hibernation" features of WinXp, you can safely delete "hyberfill" of C: by
display properties-screen saver -power setting-uncheck hibernation.
this will save harddisk space equal to the amount of your "RAM" and it will help to make image backup of your c: drive small.
Old 09-04-2007, 12:10 AM   #7 (permalink)
pro
pro's Avatar
problem solved ........
peacefully.
pro is offline
can SP2 be installed over existing XP pro? devips Software Q&A 5 03-02-2007 10:03 AM
win 98 can't be installed. amit.sirsi Software Q&A 18 15-12-2006 09:41 AM
How often should Windows be re-installed? tuxfan Software Q&A 21 10-10-2005 11:15 PM
Accidently all Inbox msgs Deleted.. Help!!!! Dipen01 QnA (read only) 6 29-03-2005 09:02 PM
- by Niilesh
- by chris
- by gforz
