Old 02-04-2007, 12:19 AM   #1 (permalink)
காத
Exclamation My XP Auto Logins... I hate it!!
My XP installation CD is created with "Unattended CD creator" where in i checked the auto login check box while creating the unattended XP Disk.
How do I turn the feature OFF in my insalled OS?? At present i ve changed my passwd so that the auto login prompts me an error message and then shows the login dialog to type my password...
Hoping for your solutions,, techies..
Prabhagaran
Prabhagaran is offline
Old 02-04-2007, 12:33 AM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: My XP Auto Logins... I hate it!!
Control Panel-> User Account - > Change the way users log on or off-> Use Welcome Screen [check the box]
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 02-04-2007, 02:51 PM   #3 (permalink)
காத
Hey thanks for the reply,
but gentle man, i ve tried that option already...
even then in automatically logs in to my account...
Regards,
Prabhagaran
Old 02-04-2007, 02:56 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
download and use ms powertoy 'tweakui' to do it on-the-fly
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 03-04-2007, 12:41 AM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Type control userpasswords2 in RUN dialog box and enable the option "Users must enter username and password to use this computer".
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 04-04-2007, 12:22 PM   #6 (permalink)
Hi Vishal,
I think You are right. Basically this command is used to Disable or enable the Autologin in Windows XP SP2.
Thanks buddy....
Regards,
Bipul Singh
bipshee1234 is offline
Old 04-04-2007, 02:13 PM   #7 (permalink)
காத
Yes of course, it worked fine.... My problem solved.......
Thank Youuuuuuuuuu
Regards,
Prabhagaran
Old 04-04-2007, 02:51 PM   #8 (permalink)
The Blessed one
s18000rpm,thanks for the solution.Even I was looking for it!
fatguysmart is offline
multiple logins in yahoo! sridhar8310 QnA (read only) 5 28-05-2005 12:22 AM
- by Niilesh
- by chris
- by gforz
