hi guys
when i run windows media player or windows picture viewer an error comes up... showing that gdiplus.dll file is missing...
iv downloaded it from the net but dont know wat to do next
actually i ran a software related to registry cleaning n that i think created this problem..
plzz help me .... ASAP.
hi guys
paste that dll file in c:\windows\system32
open run command...and write regsvr32 gdiplus.dll there..press enter and ur dll will be loaded into registry..and be alert of registry cleaning softwares...use only the gud once..like PC tools registry mechanic..
i did as alok said... but it said that the file cannot be loaded... "gdiplus.dll was loaded, but DLLRegisterServer entry point was not found" wat to do now?????
Another suggestion i could give is running the command , SFC / SCANNOW it would scan the system for missing files and may ask your Installation media to copy any missing files !!
