I am using opera from quite sometime now
the problem is dat from a few months i cant c any animation while browsing in opera at all like animated avtar etc
but if i use ie 7 then i am able to c all the animations
dont know wat is wrong wit opera?
any help i dont wann use ie
Caught the culprit. Its been a while since I used Windows so I have forgotten the option, but there is a preference in Spy Sweeper that disables these images. Look for it or wait for someone else to give you the exact option.
I was having the same problem after installing this program and I clearly remember there was an option that I had to disable.
Do this. Quit the program completely and restart Opera. I am sure you'll see the images.
no didnt help either
i uninstalled everything opera my firewall{zonealarm}
xp service pack 2 and then installed them again but for no gain
any other sugesstion plz
