Old 30-03-2007, 11:41 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default problem with outlook
hi friends,
i got problem with my office outlook. my mails are going from my outlook but its not reaching the concenr person.
another problem is that i am able to download yahoo mails using yahoo pop to my outlook but unable to send the messages.
thanks
Once a new technology rolls over you, if you're not part of the steamroller, you're part of the road
kunaltech is offline
Old 02-04-2007, 06:49 PM   #2 (permalink)
morpheusv6's Avatar
Default Re: problem with outlook
Does that happen with all the email addresses or only specific ones?
The email address may have been mispelled.
Deven
morpheusv6 is offline
Old 02-04-2007, 09:09 PM   #3 (permalink)
thinkdigitreader's Avatar
Smile Re: problem with outlook
Facing problem in configuring yahoomail with outlook... Here is the solution...
1. Open your yahoo mail account.
2. On the right side, u will see - Options. Click it.
3. Then go to - POP Access and forwarding.
4. Check 'Web and POP Access' and When downloading new messages: I don't want to receive any messages that SpamGuard thinks are spam
5.Open outlook or outlook express.
6.Click the 'tools' menu and select 'accounts....'
7.Click 'Add', and then click 'mail...'
8.Enter your name in the 'Display name:' field, and click 'Next.'
9.Enter your full yahoo email address in the 'Email address:' field, and click 'Next.'
10.Enter 'pop.mail.yahoo.com' in the 'Incoming mail (POP3, IMAP or HTTP) server:' field. Enter 'smtp.mail.yahoo.com' in the 'Outgoing mail (SMTP) server:' field.
11.Click 'Next.'
12.Enter your Yahoomail username (including '@yahoo.com') in the 'Account name:' field. Enter your yahoomail password in the 'Password:' field, and click 'Next.'
13.Click 'Finish.'
14.Highlight 'pop.mail.yahoo.com' under 'Account,' and click 'Properties.'
15.Click the 'Advanced' tab.
16.Check the box next to 'This server requires a secure connection (SSL)' under 'Outgoing Mail (SMTP).'
17.Enter '465' in the 'Outgoing mail (SMTP):' field.
18.Check the box next to 'This server requires a secure connection (SSL)' under 'Incoming mail (POP3) and 'Outgoing mail (SMTP) both.' The port will change to 995.
*The order of 'Outgoing' and 'Incoming' mail server fields varies by version. Make sure you enter the correct information in each field.
19.Click the 'Servers' tab, and check the box next to 'My server requires authentication.'
20.Click 'OK.'
Congratulations! You're done configuring your client to send and retrieve Yahoomail messages.
And its all for free!
Regards,
ThinkDigitReader
"Knowledge Multiplies By Dividing"
thinkdigitreader is offline
Old 03-04-2007, 03:55 AM   #4 (permalink)
in terms of office outlook problem yes its happen with all email id
and can i for yahoo problem i will check and let u know thinkdigiter
Old 03-04-2007, 05:20 AM   #5 (permalink)
sumeet singh's Avatar
Thumbs up Re: problem with outlook
u must be getting an error no. also
a number like >>> 0x800 something
take the number and serch it in google
u will be given a resolution for that error
try it!!
I am nOt paId EnOugH tO bE nIcE tO U!!!
sumeet singh is offline
Old 03-04-2007, 10:59 AM   #6 (permalink)
sumeetindia's Avatar
Have you propely setted the SMTP of gmail as 465 SSL
Google dosent use the default i.e. 25
Yahoo''s SMTP port is :465 SSL
Also try using http://toolbar.google.com/gmail-helper/GmailConfig.exe
To configure your client automatically.
See if that helps
If all this dosent help
Try using THUNDERBIRD
Sumeet
www.fultoomobile.com - Free Hindi Ringtones and mobile wallpapers
sumeetindia is offline
Old 04-04-2007, 04:36 PM   #7 (permalink)
tuxfan's Avatar
If the mails are going successfully from Outlook, then it is working properly. The problem seems to be with your ISP's SMTP server. Or may be the recepient has installed some junk mail filter and your mails are marked as spam.
Check the SMTP settings. See the help provided at Yahoo's site and follow the steps. What error are you getting?
tuxfan is offline
Old 05-04-2007, 04:07 PM   #8 (permalink)
well i am able to recieve yahoo mails properly but while sending i am getting he below message. my smtp are correct
Task 'pop.mail.yahoo.com - Sending' reported error (0x8004210B) : 'The operation timed out waiting for a response from the sending (SMTP) server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).'
Old 05-04-2007, 05:04 PM   #9 (permalink)
can u tel me ur version of outlook
check for ur server timeout in outlook setting also
:P If U lIkE mY SUggeStIon Plz ADd SOmeThing tO mY RePUtaIon :)
Last edited by buntythecool; 05-04-2007 at 05:04 PM. Reason: Automerged Doublepost
buntythecool is offline
Old 07-04-2007, 11:55 PM   #10 (permalink)
well its going but taking long time for process. for 10kb mail its taking 5 minutes
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/53784-problem-outlook.html
problem with outlook Software Troubleshooting Question This thread Refback 21-01-2011 05:43 PM
Outlook problem executioner QnA (read only) 3 13-06-2006 11:24 AM
Outlook problem nishant_nms Software Q&A 3 03-01-2006 10:23 PM
Outlook Problem! yog786@vsnl.com QnA (read only) 2 20-07-2005 06:03 AM
MS Outlook with Norton--------- Problem khattam_ Software Q&A 2 09-04-2005 01:51 AM
outlook problem aathif QnA (read only) 1 05-04-2005 01:07 AM
- by Niilesh
- by chris
- by gforz
