Old 30-03-2007, 02:33 PM   #1 (permalink)
gofeddy's Avatar
Default ms32dll.dll issue?
Hello,
I have a problem in my comp. The moment I start up my comp, I get a text file about ms32dll.dll.vbs
When I open IE, in my title bar, it says "Hacked by Godzilla"
I double click on my drives and they dont open. But a script file wscript.exe is running.
I checked out for solutions on the net. But they dont work.
Is there a solution that 100% works to remove this problem?
I also scanned my system using avast, reg cleaner, tune up..... but of no use
At any moment of time, the BEST thing to do is the RIGHT thing, the NEXT BEST thing is the WRONG thing, and the WORST thing to do is NOTHING
gofeddy is offline
Old 30-03-2007, 03:07 PM   #2 (permalink)
shantanu's Avatar
Default Re: ms32dll.dll issue?
i think your computer is have a visual Basic Script... just delete that file and you are done.. search it and delete it....
shantanu is offline
Old 30-03-2007, 03:19 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
download and use foll tool/s :
Godzilla remover
or
Godzilla Fixer
reboot.
then do a pc cleanup with ccleaner
reboot again.
hope it helps else post ur hjt logfile.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 30-03-2007, 08:00 PM   #4 (permalink)
gofeddy's Avatar
i tried using all your methods. but it did'nt work. the same problem continues.
anything else???
I installed avast only after hearing and looking at the support it had from the members here. and this is the first time it has given me a problem.
Then which av do you recommend?
gofeddy is offline
Old 30-03-2007, 09:17 PM   #5 (permalink)
Mclaren F1 Long tail
aneesh kalra's Avatar
Go to run and type mrt.exe
Computers are like air conditioners. They work fine until you start opening windows.
aneesh kalra is offline
Old 30-03-2007, 10:23 PM   #6 (permalink)
anandk's Avatar
y dont u PLEASE post ur hjt logfile ???
Microsoft® MVP
anandk is offline
Old 31-03-2007, 11:40 AM   #7 (permalink)
gofeddy's Avatar
OK Here's the logfile:
Logfile of HijackThis v1.99.1
Scan saved at 11:36:48 AM, on 31.03.2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Comodo\Firewall\cmdagent.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Comodo\Firewall\CPF.exe
C:\Program Files\Google\GoogleToolbarNotifier\1.2.1128.5462\G oogleToolbarNotifier.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\Opera\Opera.exe
C:\Documents and Settings\abc\My Documents\hijackthis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page =
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Hacked by Godzilla
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {4C220A68-A82D-40D0-9232-002EBEC2B24E} - (no file)
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar3.dll
O2 - BHO: (no name) - {BA463437-C3DE-47da-8280-87596824388A} - (no file)
O2 - BHO: FDMIECookiesBHO Class - {CC59E0F9-7E43-44FA-9FAA-8377850BF205} - C:\Program Files\Free Download Manager\iefdmcks.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar3.dll
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [COMODO Firewall Pro] "C:\Program Files\Comodo\Firewall\CPF.exe" /background
O4 - HKLM\..\Run: [MS32DLL] C:\WINDOWS\MS32DLL.dll.vbs
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\1.2.1128.5462\G oogleToolbarNotifier.exe
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O7 - HKLM\Software\Microsoft\Windows\CurrentVersion\Pol icies\System, DisableRegedit=1
O8 - Extra context menu item: Download all with Free Download Manager - file://C:\Program Files\Free Download Manager\dlall.htm
O8 - Extra context menu item: Download selected with Free Download Manager - file://C:\Program Files\Free Download Manager\dlselected.htm
O8 - Extra context menu item: Download with Free Download Manager - file://C:\Program Files\Free Download Manager\dllink.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O17 - HKLM\System\CCS\Services\Tcpip\..\{866CCC72-D2A7-40FB-AA3D-A14D6C84C492}: NameServer = 61.1.96.69,61.1.96.71
O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxdev.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: Comodo Application Agent (CmdAgent) - COMODO - C:\Program Files\Comodo\Firewall\cmdagent.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
gofeddy is offline
Old 31-03-2007, 07:35 PM   #8 (permalink)
gofeddy's Avatar
I fixed those issues that Indyan pointed out. But after I reboot the system, the same problem appears again.
I think there must be something else that's triggering this ms32dll.dll.vbs.
Keep posting your solutions.........
gofeddy is offline
Old 15-04-2007, 03:58 PM   #9 (permalink)
Smile Re: ms32dll.dll issue?
Hi even i had the same problem, however i managed to remove it,herez how--
[detailed xplanation given aftrwardz]
1.In taskbar (CNTRL+ALT+DEL) go to processes and close all instances of 'wscript.exe'
2.Open My computer, in tools->folder options->view-> check 'show hidden files and folders' and uncheck 'Hide protected operating system files'.
3.Now in all your drives two files with READ ONLY attributes will be visible- ms32dll.dll.vbs and autorun.inf
4 Delete these two files from all the drives
5 In C:\Windows\ there will be another ms32.dll.vbs file, delete this also
6 Remember during all this process don't double click your hard disk, if u do then follow step 1,then continue.
7 Open registry editor (Start->Run->regedit) Make following changes in registry-
go to HKCU\Software\Microsoft\Internet Explorer\Main,and change Window Title = Microsoft Internet Explorer
and
HKLM\Software\Microsoft\Current Version\Run and delete the entry ms32dll.dll
8 And if u click ur drive icon then repeat the process 4m step 1
9 Restart and relax itz back to normal
Geeked Out!!!
dhairyadand is offline
APC - UPS issue sam9999 Hardware Q&A 8 29-12-2006 12:21 AM
RD RAM issue urvish_acharya Hardware Q&A 5 25-08-2006 02:13 PM
RAM Issue.. dreams Hardware Q&A 13 26-01-2006 08:51 AM
RAM Issue speedyguy Hardware Q&A 13 20-01-2006 06:11 PM
- by Niilesh
- by chris
- by gforz
