Old 28-03-2007, 11:19 PM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Question Fix MBR
I messed up with my mbr i suppose.
initially i had 2 os both xp. then i had installed Mandrake few months ago after that. then i just removed mandrake by deleting tht partition(on which mandrake was installed) thru xp. but tht new boot menu still remained.
today i had formated tht free space. it did show some logical disk warning but i ignored it.
then the next time turn on, the new boot menu was no more their.
i can boot through my XP Home cd and get into the recovery console. theres fixmbr and fixboot option..i cant figure wht should i choose?
please help.
ps:i m posting through mobile..so plz neglect any typo errors.
http://twitter.com/blueshift155
blueshift is offline
Old 28-03-2007, 11:27 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: Fix MBR
try going thru the boot.ini file in msconfig might b of some help ...
http://beingmanan.com
iMav is offline
Old 28-03-2007, 11:32 PM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Fix MBR
I cant login to any of the Windows. i dont get tht boot list at all..just some garbage values.
or u telling under Recovery console?
Old 28-03-2007, 11:34 PM   #4 (permalink)
iMav's Avatar
Default Re: Fix MBR
try the recovery console if u cant go into windows ... u can only edit boot.ini after ur into windows until unless some dos guy tells u the dos path to it
iMav is offline
Old 28-03-2007, 11:39 PM   #5 (permalink)
Google Bot
Pathik's Avatar
Default Re: Fix MBR
goto the recovery console nd type fixboot and fixmbr.. That shd reinstall the xp default boot loader in d mbr.. And u shd b able to boot into xp.. @mav repairing boot.ini wont work wen non ms oses r installed on xp
Pathik is offline
Old 28-03-2007, 11:41 PM   #6 (permalink)
iMav's Avatar
Default Re: Fix MBR
^^ thanx for that didnt know it ...
iMav is offline
Old 28-03-2007, 11:52 PM   #7 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Fix MBR
Thanks pathiks and mav3 for ur replies. wil try tht tommorow morning.
Old 28-03-2007, 11:53 PM   #8 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Fix MBR
If u r not getting the XP loader too, then try following sequence of commands:
fixmbr
fixboot
bootcfg /rebuild
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 29-03-2007, 01:02 AM   #9 (permalink)
sauravktr's Avatar
Default Re: Fix MBR
Boot with 98 bootable Cd & type "fdisk /mbr" in prompt without the qoutes.this may be solve ur problem
sauravktr is offline
Old 29-03-2007, 01:09 PM   #10 (permalink)
Default Re: Fix MBR
Hey friend choose fixmbr option. Once a day I install Mandrake and then I formatted the partition on which it was installed. I go to recovery console choos fixmbr and voila! it was done.
abhijangda is offline
Old 29-03-2007, 01:46 PM   #11 (permalink)
piyush gupta's Avatar
Default Re: Fix MBR
fixmbr
fixboot
bootcfg /rebuild
It will work as i also used this command when i was using 98 adn XP as dual boot and by mistake changed my bo0t to C:
piyush gupta is offline
Old 29-03-2007, 01:52 PM   #12 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Fix MBR
Yeah. my problem is solved. thanks everyone.
- by Niilesh
- by chris
- by gforz
