Old 22-03-2007, 11:38 PM   #1 (permalink)
Default DVD Writer Problem
Hi
Can anyone please solve my problem.
I have an Amd Athlon 64 bit system with 1 gb of ram and i have been using a Sony Dvd writer for a year and a half but suddenly i started facing problems with it, when ever i used to load a DVD or a Cd it used to use all my computer resources and would make my system really slow.
It took about 5 hours to write a 4.6 GB dvd and about 20 min to copy a 700 mb file.
So i bought a new writer and installed it in my system (Sony DRU 170 C) just a couple of days before.
It ran fine for a week but now it is also giving me the same problem.
Can anyone tell me where my problem is located cause i dono where to look for it.
Thanks
caveman is offline
Old 22-03-2007, 11:59 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: DVD Writer Problem
Its some kinda conflict with the IDE controller or some hardware resource sharing problem. Try making it slave or master[opposite to the one uve been using].
Also connect the drive alone in a seperate IDE cable if uve a free IDE slot in ur mobo. This is sure to solve the problem.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 23-03-2007, 01:18 AM   #3 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
In your BIOS try enabling DMA for the HDD & DVD Writer.
Try disabling antivirus and other resource hungry applications when you burn
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 23-03-2007, 08:08 AM   #4 (permalink)
nishant_nms's Avatar
check the DMA status
nishant_nms is offline
Old 23-03-2007, 09:02 AM   #5 (permalink)
aj27july's Avatar
ya do what mod-the-pc says
it should help
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 23-03-2007, 09:19 AM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
Try resetting the DMA
Use this tool
Else, reinstalling XP will solve the problem.
Same problem discussed here, here and here. See the solutions
Nokia N86 8MP
Lucky_star is offline
Old 23-03-2007, 11:00 PM   #7 (permalink)
i'll surely try all the possibilities today thanks a ton!!!!!
If i still have a problem i'll surely write back
Thanks once again
__________
yah that did solve my problem thanks a toon!!!!!!
caveman is offline
Old 23-03-2007, 11:36 PM   #8 (permalink)
Still Shining!
Lucky_star's Avatar
Well, So, DMA was the culprit...
Nokia N86 8MP
- by Niilesh
- by chris
- by gforz
- by Anorion
