Old 22-03-2007, 10:22 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Hibernating Not working??
Frnds when i hibernate my PC and restart it...
after recovering from hibernation, it just restarts ...
wat is wrong??
Manshahia is offline
Old 22-03-2007, 11:07 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Hibernating Not working??
Does it reboots or enters into Hibernation mode again?
Kiran Kumar R
Kiran.dks is offline
Old 23-03-2007, 05:51 AM   #3 (permalink)
Resident Fanatic
Manshahia's Avatar
after restart, it says that hibernation failed...
do u want to delete the restoration data or restart again??
Old 23-03-2007, 08:16 AM   #4 (permalink)
nishant_nms's Avatar
update ur drivers
nishant_nms is offline
Old 23-03-2007, 11:15 AM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
whilst on the topic:
i am facing this wierd problem since last nite:
i hibernate ... it hibernates now instead of shutting down it restarts and it continues from where i hibernated but when i hibernate the pc does not shut down after hibernation but restarts
http://beingmanan.com
iMav is offline
Old 23-03-2007, 01:34 PM   #6 (permalink)
Kiran.dks's Avatar
It may be driver problem that is causing improper Hibernation. Check the Event logs.
Kiran Kumar R
Old 23-03-2007, 02:02 PM   #7 (permalink)
iMav's Avatar
ne suggestions for my problem
iMav is offline
Old 23-03-2007, 05:42 PM   #8 (permalink)
Kiran.dks's Avatar
Please frame the question properly. I am not able to understand what exactly is the problem.
Kiran Kumar R
Old 23-03-2007, 05:46 PM   #9 (permalink)
iMav's Avatar
i click hibernate .... it starts to hibernate .... it shows me "windows is preparing to hibernate" .... then it should shut down the pc once done (power off) but instead it restarts the pc
i hope i made it clearer
iMav is offline
Old 23-03-2007, 06:14 PM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
^did you try deleting the Hibernation file?? (disable the "Hibernate" option, it'll delete the hiber... file.
& also you two check for any disk errors.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 23-03-2007, 06:17 PM   #11 (permalink)
iMav's Avatar
ill try tht but just to add tht once it restarts it starts from where it hibernated ... ie. it continues from where i last left
iMav is offline
Old 23-03-2007, 08:26 PM   #12 (permalink)
Kiran.dks's Avatar
Since your Hibernating session is resumed after restart, it means there is no problem in data writing to the hard disk. It seems like something is waking up the Hibernation mode. It may be a ping due to updates via network adapter. Check the network settings.
Kiran Kumar R
Old 23-03-2007, 10:55 PM   #13 (permalink)
iMav's Avatar
check them for what ... all of a sudden this is happening and even IE has started popping up stupid windows ... i think im infected by some adware
iMav is offline
- by Niilesh
- by chris
- by gforz
- by Anorion
