Old 22-03-2007, 02:54 PM   #1 (permalink)
Default start up problem
friends,
whenever my windows starts after booting i see my documents folder rather than the desktop. please suggest some ways to fix that
ritish is offline
Old 22-03-2007, 02:56 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: start up problem
might be accidently placed in stratup
go to Run>msconfig>startup>disable all
then restart
i think that should do it
Tech Geek is offline
Old 23-03-2007, 02:02 PM   #3 (permalink)
hey buddy that didn't work
suggest some other way
ritish is offline
Old 23-03-2007, 11:22 PM   #4 (permalink)
Fresh Stock Since 2005
RontokGen virus suspected in your computer... Scan with a good antivirus software... Have a look at the tutorial section titled "Rontok Removal" by me....
Scan your computer with a Gud updated antivirus...
Download HijackThis from http://www.majorgeeks.com/download3155.html and Run it and "Do a System Scan and save a log file" and post the logfile here for further assistance.....
http://www.khattam.info
khattam_ is offline
Old 24-03-2007, 01:54 AM   #5 (permalink)
Kiran.dks's Avatar
Start>Run>regedit
Propagate to HKEY_CURRENT_USER \ Software \ Microsoft\Windows NT\ CurrentVersion \ Windows
In the right pane, check settings under "Load". There should be no value. If you find any value in load, delete it.
If there is no value, then your system is infected with DlDer Trojan.
Download & install freeware "Spybot"-Search & Destroy and scan entire system in "safe mode".
Kiran Kumar R
Kiran.dks is offline
Old 26-03-2007, 09:33 PM   #6 (permalink)
please can anyone provide me a link for the patch to the virus
ritish is offline
Old 26-03-2007, 10:28 PM   #7 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
@khattam, its Rontokbro and ritish refer the link to remove it http://www.xblock.com/product_show.php?id=2845
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 26-03-2007, 10:47 PM   #8 (permalink)
Kiran.dks's Avatar
It is a Advertising Spyware named DLDER. This spyware trojan consists of two executable files, dlder.exe and C:\Windows\explorer\Explorer.exe. The dlder.exe file then places a Run key in the Registry so that the new Explorer.exe trojan runs at startup.
Here is the removal tool: DLDER Remove
More Info about the Trojan
Kiran Kumar R
Old 27-03-2007, 07:57 PM   #9 (permalink)
that does not solve the problem friends
ritish is offline
Old 27-03-2007, 08:12 PM   #10 (permalink)
Kiran.dks's Avatar
That's strange. Did u check the registry values as I said above?
OR
The best thing would be to install freeware spybot-Search & destroy and scan entire system. Did u do that?
Kiran Kumar R
Old 27-03-2007, 10:24 PM   #11 (permalink)
Distinguished Member
anandk's Avatar
try this :
Run regedit and navigate to:
HKLM/SOFTWARE/Microsoft/Windows NT/CurrentVersion/Winlogon
In there there should be a value (on right hand side of screen) called Userinit.
The data for this value is probably something similar to:
C:\windows\system32\userinit.exe,C:\windows\system 32\userinit.exe,
If you do see a duplicated string in there similar to the above - simply double click on the Userinit value and edit the data so as to delete everything to the right of the first comma (,). In the case above you would leave only:
Exit registry edit and reboot.
http://www.techspot.com/vb/all/windo...winxp-sp2.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
- by Niilesh
- by chris
- by gforz
- by Anorion
