Old 21-03-2007, 04:43 PM   #1 (permalink)
!FREEWARES!
Akshay's Avatar
Default Lock folders in XP without ne s/w.
Came across dis useful trick on d net. I want to know the reason/logic behind this process.
Suppose you want to lock the folder abc in c: which has the path c:\abc. In the same drive create a text file and type
ren abc abc.{21EC2020-3AEA-1069-A2DD-08002B30309D}
Now save this text file as lock.bat
create another text file and type in it
ren abc.{21EC2020-3AEA-1069-A2DD-08002B30309D} abc
Now save this text file as key.bat
Now you can see 2 batch files lock and key.Press lock and the folder lucky will change to control panel and you cannot view its contents.Press key and you will get back your original folder.
Y does this happen?
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 21-03-2007, 04:56 PM   #2 (permalink)
MVP Awardee 07
uzair's Avatar
Thumbs up Re: Lock folders in XP without ne s/w.
Awesome work man
i presume the class id u specified is of control panel's...
coz when i changed it to {21EB2020-3AEA-1069-A2DD-08002B30309D}
i got a normal folder...
clicking it opens the open with dialog.....
Probability of me getting a ps3=0
Probability of me getting crazy about ps3=1
uzair is offline
Old 21-03-2007, 05:45 PM   #3 (permalink)
dOm1naTOr's Avatar
Default Re: Lock folders in XP without ne s/w.
The small utility called 'fake folder' makes use of same trick. And u need a password to operate fake folder.
@uzair
the same avatar of urs is already used by one of the old user 'knivor'. Seems confusing.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 22-03-2007, 12:21 AM   #4 (permalink)
Mad and Furious
redhat's Avatar
Thread already started at:
LOCK FOLDERS w/o any S/w
Plus,
I have created an app. that models this type of locking in Visual Basic. The thread for that is running at:
Locking folders without commercial softwares.
__________
If anyone wants to know its working:
Whenever you attatch a ".{CLSID}" to a folder as an extention, windows recognizes that folder as a special folder under that CLSID. So if the CLSID for My Computer is used, windows will recognize the folder as my computer and open My Computer when double-clicked! You can learn more about CLSID's from the Fast Track to Registry that came along wit the Digit Mag, some time ago.
SOURCE: I came across this trick by accident when I pasted a CLSID after the folder name by mistake.
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 22-03-2007, 08:06 AM   #5 (permalink)
Learner
Kniwor's Avatar
@uzair
Will you stop using my avatar and create one for urself.
Even I myself got confused.
Kniwor is offline
Old 22-03-2007, 12:23 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by Kniwor
@uzair
ha ha ha..Avtar war,never heard abt it..but can see now.
ravi_9793 is offline
Old 27-03-2007, 05:00 PM   #7 (permalink)
MVP Awardee 07
uzair's Avatar
ok man chill
u win
Y does this happen?
Check out these cool clsid's on this link...
http://www.autohotkey.com/docs/misc/CLSID-List.htm
uzair is offline
Old 27-03-2007, 05:01 PM   #8 (permalink)
Lean mean A@# kickin M/C
apoorv.sharma's Avatar
^^^hahah he still hasnt changed it!...gawd ure pathetic!...
It's hard to soar like an eagle when you're working with turkeys!
apoorv.sharma is offline
Old 27-03-2007, 05:17 PM   #9 (permalink)
MVP Awardee 07
uzair's Avatar
Angry Re: Lock folders in XP without ne s/w.
Y does this happen?
Is that Enough huh!!!
uzair is offline
Old 27-03-2007, 11:47 PM   #10 (permalink)
knight17's Avatar
^^ That was useful
"It's not a silly question if you can't answer it." Sophie's World [ http://en.wikipedia.org/wiki/Sophie's_World ]
knight17 is offline
- by Niilesh
- by chris
- by gforz
- by Anorion
