Old 21-03-2007, 09:37 AM   #1 (permalink)
Unhappy partition problem on hp laptop
i just got a hp laptop
they gave me vista on it
the problem is it got only 1 single drive of 120 gb
now i askd hp ppl to give me vista dvd . so i could reinstallit in future if needed..
also ineed it after partiotioning..
but they said they wont give dvd but i have to make a recovery disc..
here's where the problem starts
if i restore from recovery disc it will make a one single partition
i tried partition magic but nothing happened..
any idea guys ?
HELP!!
anonymusneo is offline
Old 21-03-2007, 11:08 AM   #2 (permalink)
Tech Geek's Avatar
Default Re: partition problem on hp laptop
it should be done while installing Vista..
nothing can be done now...
Tech Geek is offline
Old 21-03-2007, 12:04 PM   #3 (permalink)
digiFriend's Avatar
if you instist ,and ready to pay just few more Rs they might give OS on seperated dvd. (one of my friend was about to return his Laptop of other brand then your, that company gave him seperate OS cd while charging just few Rs more).
you never know what you can do until you try
digiFriend is offline
Old 22-03-2007, 03:42 PM   #4 (permalink)
i'll try asking forr dvd
Old 22-03-2007, 04:14 PM   #5 (permalink)
I have Yolks not Brains!
eggman's Avatar
Well you can repart your harddisk, thanks to the Inbuilt partionmanager of vista(A less known feature).
>>Go to CONTROL PANEL
>>And Then In ADMINSTRATIVE TOOLS
>>Select COMPUTER MANEGMENT
>>In COMPUTER MANAGEMENT go to STORAGE>DISC MANAGEMENT
Here you can see the map of your harddisk.
Right Click C: drive and select SHRINK VOLUME.
Select the amount you want for new volume and OK.
Unalloter space will be created.Select the unalloted space,right click it and make new volume.
Y U NO ALLOW PICTURES IN SIGNATURES?
eggman is offline
Old 22-03-2007, 09:18 PM   #6 (permalink)
uchiha.sasuke's Avatar
hey dude same prob. here .......but still searching for solution...
True Power lies within the blood of your peoples revenge...The devils fruit can lead me there...
uchiha.sasuke is offline
- by Niilesh
- by chris
- by gforz
- by Anorion
