Old 20-03-2007, 11:54 PM   #1 (permalink)
Anindya's Avatar
Question Torrent problem.
Hello, I dont know whether its illegal to ask about this problem or not. If its illegal then please tell me and delete or lock the thread. I use Utorrent. While using it in the status bar where it shows whether the connection is correct or not, the sign given is an exclamation mark and it says that ' No incoming connection Unless the light turns green it could mean there is a problem with ur network' How can i rectify it. The port given in the setting is 57661.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 21-03-2007, 12:14 AM   #2 (permalink)
sam_1710's Avatar
Default Re: Torrent problem.
it means dat your port is not being forwarded...
so visit : www.portforward.com and check out the instructions given there!!
u'll require this : http://www.portforward.com/english/r...outerindex.htm
sam_1710 is offline
- by Niilesh
- by chris
- by gforz
- by Anorion
