Old 20-03-2007, 12:16 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Genuine WinXP Home Edition Problem......?
My friends has HP Pavillion dv5000 which he has buyied from Dubai
He didnt got any CD's or Softwares with it
He only got Laptop & a free Laptop Bag
But he says the WinXP home edition in it was original,
their was some problem in its Laptop so i reinstalled WInXP_Professional in its C drive which is a pirated version
Now Pls tell me how can i get back that Genuine WinXP home
In the bottom of his Lap their is one serial key no written which is of WinXP Home edition
Now its C drive has both WinXP_professional & home
see my previous thread for this problem
http://www.thinkdigit.com/forum/show...066#post450066
When his lap was new it had 2 partition C & D & d had some sapce reserved which was called Recovery area & he had a HP software installed in it call HP Recovery (something like this)
now in New WinXP professional D dont have this space also from where can i get that win
I cant contact HP for this nor the methods system recover works
My question is
I want to make his lap as it was on the First day ............? how can i.......?
Can I get that WinXP home edition back with that recovery software.........?
Pls help
Pls help.......................
satyamy is offline
Old 20-03-2007, 12:28 PM   #2 (permalink)
Q6600 Underclocked
sourishzzz1234's Avatar
Default Re: Genuine WinXP Home Edition Problem......?
Seems tooooooo much complicated for me..
better have the original Win XP home /Pro CD with key delete all partitions -create new partitions and the install the OS.. its simple just u nedd to have a good computing knowledge-follow the instructions while installing the OS from the CD and and and U NEED to havea BOOTABLE XP CD
sourishzzz1234 is offline
Old 20-03-2007, 01:03 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
as i already told
i dont have any HP or Genuine Windows CD
I only have a Serial No. of WinXP_Home Edition
can i install windows from other winXP home edition cd & then put this original no in it..............?
satyamy is offline
Old 20-03-2007, 02:20 PM   #4 (permalink)
The joy Of Wow
kirangp's Avatar
well u will have to go for a trial error method dude...U have to install windows xp home(indian version) & try to give the dubai laptop key...If u r lucky then it will accept it & no probs for u...I have tried this for Indian version key & Indian OS disk & it worked & my friend can authenticate with MS also using his key .... otherwise there might be a partitioned disk to install windows inside ur laptop(hidden)...This can be activated by pressing F2-F10 keys(i am not sure) or even delete key WHILE BOOTING THE LAPTOP.....try that...it might work...why in the hell branded companies dont give OS install disk???They just want to save costs & reap benefits of after sales service(cash $$$) from the customer...or best bet reformat laptop & give it to HP & ask them to install windows & give it back....The last option will cost u money for sure if u dont have global warranty
The right man in the wrong place can make all the difference in the world
kirangp is offline
Old 20-03-2007, 03:40 PM   #5 (permalink)
aj27july's Avatar
no. you can't get the xp home back. go for xp pro as you have its installation cd. and xp pro is better and safer than xp home. but you can try putting the xp home jey into the setup of xp pro! this might work. it worked for me when i put my original licensed xp pro key into xp media center edition!!!
best of luck
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 20-03-2007, 04:06 PM   #6 (permalink)
You gave been GXified
gxsaurav's Avatar
it won't work.
You can go to HP support, they will help. Atleast try
Your 2nd option is to download Windows XP home edition retail\OEM CD ISO from somewhere & use that key in it
about.me/gxsaurav
gxsaurav is offline
Old 20-03-2007, 04:34 PM   #7 (permalink)
aj27july's Avatar
@gx_saurav
i myself tried the xp pro key on xp mce
it worked.
all the softwares in xp pro and xp home are the same. but the specific keys activate only specific programs. in vista also, all the versions have same programs, the programs activated are specific to that key. understood?? u can even compare the sizes of the different vista versions, they will have the same size.
----OSHO
aj27july is offline
Old 20-03-2007, 05:37 PM   #8 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
@satyamy - the recovery partition contains the files needed for restoring XP home back in the laptop. Press F11 during boot to start recovery
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 20-03-2007, 07:37 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
try the Standard Recovery.
press F11 as mod_pc... said
DONT DELETE/FORMAT D: Drive.
when XP Installs successfully, FIRST goto to Start->All Programs-> PC Help & Tools -> Create Recovery Disks
this'll create Recovery Disks.
with HP OEM XP Home, you get free HP softwares (Image Zone Plus, AV s/w, ....)
get 2 DVD & just follow the on screen instruction.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 20-03-2007, 11:04 PM   #10 (permalink)
Alive Again...
satyamy's Avatar
Question Re: Genuine WinXP Home Edition Problem......?
From where to get the 2 DVD
satyamy is offline
Old 20-03-2007, 11:08 PM   #11 (permalink)
a_g = JPKN
s18000rpm's Avatar
no, i meant 2 empty DVD's, to burn /make as Recovery Disks
Old 21-03-2007, 07:48 PM   #12 (permalink)
Booting Nicotine!!
spironox's Avatar
HP Pavillion dv5000 try getting the recovery cd for no hassel recovery from HP guys or follow the s18000rpm instruction the dude is a HP user i guess he knows the trick very well
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
spironox is offline
Old 21-03-2007, 11:20 PM   #13 (permalink)
TechTin.com
ravi_9793's Avatar
just format whole drive.............get a pirated version of windows XP Home edition...but use ur own key while installing Xp...and install it.
Yiu will get ur genuine windows XP Home edition.
ravi_9793 is offline
Old 21-03-2007, 11:35 PM   #14 (permalink)
a_g = JPKN
s18000rpm's Avatar
but then there's no point of paying so much for HP laptop, coz with the OEM XP, he probably had a Full version CD/DVD burner, full version Image & Video Editing s/w, preloaded m/b, audio... Drivers, HP back-up making s/w... & lot more.
just try installing thru "Standard Recovery" mode & you're saved.
you tell your friend a thing- READ THE INSTRUCTION MANUAL ATLEAST ONCE.
in that manual it would be CLEARLY STATED, that MAKE RECOVERY DISKS aS SOON as POSSIBLE.
now what will he do if the HDD crashed (after Warranty period)???
Old 22-03-2007, 02:37 PM   #15 (permalink)
aj27july's Avatar
ravi_9793 is telling the same that i told.
----OSHO
aj27july is offline
- by Niilesh
- by chris
- by gforz
- by Anorion
