Old 19-03-2007, 10:27 AM   #1 (permalink)
Red face how to create bootable cd
i am trying many times o create bootable can anybody tell me how to create bootable cd in nero 7 ultra edition thank in advance
gaurav816 is offline
Old 19-03-2007, 10:41 AM   #2 (permalink)
Tech Geek's Avatar
Default Re: how to create bootable cd
there is a option i think
Tech Geek is offline
Old 19-03-2007, 11:00 AM   #3 (permalink)
The Demun
Sinja's Avatar
u can try out the Daemon Tools were u can virtually mount the files and then run it.
Ragnarok is a way of life ^_^
Join the wonderfully addictive world of ragnarok be a Rag addict the ultimate addiction in MMORPG
Sinja is offline
Old 19-03-2007, 11:08 AM   #4 (permalink)
shashank4u's Avatar
these links will help u
for creating a bootable disk u will require boot.ini file and then
just burn like normal...and u r done..google a little bit.
http://www.bootdisk.com/
http://www.techsupportalert.com/search/t1214.pdf
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 19-03-2007, 11:16 AM   #5 (permalink)
Hey friend you can create a bootable cd by Nero Burning ROM not Nero Express. Go to help in Nero Burning ROM.
abhijangda is offline
Old 19-03-2007, 11:22 AM   #6 (permalink)
piyush gupta's Avatar
In Nero
Select Bootable Data Disk
piyush gupta is offline
Old 19-03-2007, 11:44 AM   #7 (permalink)
Resident Fanatic
Manshahia's Avatar
wat u want to write in that??
Manshahia is offline
Old 19-03-2007, 01:22 PM   #8 (permalink)
MMO Addict
amitava82's Avatar
^^ ya thats a important question.. if you want to make a bootable cd to boot the computer then its a different approach and to make a autorun cd its different. so state your requirement...
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 23-03-2007, 02:12 PM   #9 (permalink)
i want to make windows xp bootable disc,nero show two option for bootable disc
one is A drive source & second is country images
Old 23-03-2007, 02:30 PM   #10 (permalink)
Resident Fanatic
Manshahia's Avatar
must be a pirated one??
Old 24-03-2007, 09:02 PM   #11 (permalink)
Gangsta
Josan's Avatar
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
firstly you should try Nero ,,,and if it does not works for you than you can try someother softwares like ultraISO
Josan is offline
Old 24-03-2007, 09:09 PM   #12 (permalink)
MMO Addict
amitava82's Avatar
http://www.tacktech.com/display.cfm?ttid=297
Old 16-04-2007, 02:15 PM   #13 (permalink)
how to create multibootable DVD of Windows XP Professional,XP Home & Vista
AlokPankaj is offline
- by Niilesh
- by chris
- by gforz
- by Anorion
