Old 18-03-2007, 08:40 PM   #1 (permalink)
Beneath The Eyelids
The Outsider's Avatar
Default Xp Setup Problem (urgent)
got a laptop here, its a Compaq Presario C500
the config is a C2D 1.66ghz T2060, 512MB of ram.
when i run the xp setup, at the screen it asks for repairing or new installation, i chose the new installation option but it says no connected hds/mass storage devices found, its pretty obvious the hd is properly connected and its a 80 gb 5400rpm sata.
do we need to take any special measures while installing xp on a sata drive?
never installed xp on a sata drive and never bothered if there is anything different or special.
thanks for the replies, its urgent
The Outsider is offline
Old 18-03-2007, 08:57 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Xp Setup Problem (urgent)
Enter into BIOS settings and make sure that the HDD is listed there.
Also there must be an option of changing the settings for SATA HDD for legacy OS, like 98, ME or for new OS, like XP. Make sure its set for new OS XP.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 18-03-2007, 10:18 PM   #3 (permalink)
Shasanka_Gogoi's Avatar
Seems ur HDD is not detected. How can u be obvious about ur HDD. I have found even new laptops directly shipped to the dealers to have that sort of problems.
Shasanka_Gogoi is offline
Old 18-03-2007, 10:31 PM   #4 (permalink)
Hey friend first see in bios if hdd is detected or not. If it is not then see if cable and power cable are connected if there is dust between connections then clean it. If this doesn't work then get a new power cable or date cable or both and then try again. If it is detected in bios and raid is on then you have to installed sata raid driver. When you start windows setup then press f6 and use floppy to install raid driver. If this doesn't work then your hdd is probably developed bad sectors and you have to replace it.
abhijangda is offline
Old 19-03-2007, 10:13 AM   #5 (permalink)
Gangsta
Josan's Avatar
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
Hey man U must b having prob with ur bios
Josan is offline
Old 19-03-2007, 10:31 AM   #6 (permalink)
Beneath The Eyelids
got it solved that time only, had to disable "legacy os support for sata drives".
thanks all for the replies, specially Vishal.
Old 19-03-2007, 04:39 PM   #7 (permalink)
Microsoft MVP
^^ Thats what I suspected. I'm glad that it worked for u.
Old 19-03-2007, 08:25 PM   #8 (permalink)
Beneath The Eyelids
Originally Posted by Josan
use vista
yeah installed vista too after xp though it wasn't my laptop.
- by Niilesh
- by chris
- by gforz
- by Anorion
