Old 15-03-2007, 05:20 PM   #1 (permalink)
aj27july's Avatar
Default Linux graphics problem
I had installed OPENsuse 10.2 about 1 month ago. But due to graphics problem, i had to uninstall it a day after its installation. The problem is that when i set my resolution to 1024x768, the screen is blurred. It isn't possible to even see anything clearly. Its blurred a lot. But in Windows XP (my primary OS), the screen is very fine at 1024x768 resolution. I thought that there might be some problem with the dvd, so i installed another distro, but the same problem existed there also. I have tried fedora 5, ubuntu and mandriva also. But the same problem exists there also. I even set the screen refresh rate to the same value as in linux as it is in windows. But it didn't help. I set all the properties in linux as they are in use in windows. But this also didn't help. But at 800x600, linux works fine. And during the installation of the distro, i even set linux to use VESA graphics at 1024x768 resolution. But this also didn't do it.
I have intel original i845 chipset.
I don't understand why this problem exists with me. I really want to shift to linux, but this problem is not allowing me to do so.
So now i have decided you linux experts about this problem. Please help me....
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 15-03-2007, 05:39 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Linux graphics problem
Why you are posting same query two times.And for ur qestion.
I dont use linux,I am a windows guy.
ravi_9793 is offline
- by gohan89
