Old 14-03-2007, 02:18 PM   #1 (permalink)
insane's Avatar
Exclamation How to Create own Icons ??
i wanted to create a grass shaped icon..can any1 guide me how to do so ??
insane is offline
Old 14-03-2007, 02:51 PM   #2 (permalink)
Shasanka_Gogoi's Avatar
Default Re: How to Create own Icons ??
U can use any icon creating softwares. I use Axialis Icon Workshop. which i think is gr8. try it and see.
Shasanka_Gogoi is offline
Old 14-03-2007, 06:35 PM   #3 (permalink)
deepak.krishnan's Avatar
First of all if you have an image out of which the icon has to be created then import in into IcoFX http://icofx.xhost.ro
Otherwise if you have photoshop then make a image using the custom shape tool which include the shape of grass. Then import it into IcoFX and save it in the .ico format
Moreover you can make it transparent if you need using IcoFX
.dk
deepak.krishnan is offline
Old 14-03-2007, 07:36 PM   #4 (permalink)
insane's Avatar
thanks a many guys!!
insane is offline
Old 14-03-2007, 08:27 PM   #5 (permalink)
Try ny of these
http://www.axialis.com/
http://www.awicons.com/
http://www.sharewareconnection.com/s...con-editor.htm
http://www.brothersoft.com/downloads...ing-icons.html
You can use what i use i.e icofx = http://icofx.xhost.ro/
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
Old 14-03-2007, 09:12 PM   #6 (permalink)
anilmail17's Avatar
iconfx is the best software to start with
visit my blog
www.anilsoni.wordpress.com:)
anilmail17 is offline
Old 14-03-2007, 10:41 PM   #7 (permalink)
thnks for all those links .
krrrish is offline
Old 15-03-2007, 06:16 PM   #8 (permalink)
insane's Avatar
that ws really very helpful!
insane is offline
Old 16-03-2007, 12:42 PM   #9 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
iconfx is awesome & thanx 4 links .........
ax3 is offline
- by gohan89
