13-03-2007, 07:34 PM
Unknown,Unseen,Unheard..
Generic Host Services Problem
i have an acer laptop running Windows Xp Home with Service Pack 2.Everything seemed to be running normal until 2 days before when the below Windows erroe message appeared:
Generic Host Process for Win32 services has encountered a problem and needs to close.
We are sorry for the inconvenience.
I tried doing everything to get rid of this,but nothing seemed to work.The problem occurs only when i am browsing with Firefox 2.0 or Opera 9.0.Nothing happens when the computer is lyind idle or when gaming or something.
Kindly let me know how to fix this problem.Your help will be greatly appreciated.
13-03-2007, 08:17 PM
Re: Generic Host Services Problem
Try Defragging ur HDD. Happens wth me when my HDD gets fragged too much.
KDE on ArchLinux
13-03-2007, 09:50 PM
Jack Sparrow
did u updated ur pc from microsoft??if yes then keep them off...for always...
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
13-03-2007, 09:52 PM
Never update with MS if u have a pirated version of Windows. They store the ip-addresses. Read their Privacy Policy
KDE on ArchLinux
14-03-2007, 02:11 AM
I tried doing everything to get rid of this,but nothing seemed to work.The problem occurs only when i am browsing with Firefox 2.0 or Opera 9.0.Nothing happens when the computer is lying idle or when gaming or something.
is there not any other way to get rid of it other than defragging the hard disk?and should i defrag the boot partition alone or both of them?
14-03-2007, 11:16 AM
try checking all the essential services are running or not, after reinstalling those browsers...
Lan's Deo
14-03-2007, 11:58 AM
There is an update released by microsoft for this problem.
I am assuming that you have Windows XP 32-Bit Version.
Download the WindowsXP-KB894391-x86-ENU.exe package and install it.
Restart the computer.
This should solve your problem.
For other versions of Windows, download from here.
Kiran Kumar R
14-03-2007, 12:28 PM
Defrag the Main Windows Drive and also the pagefile and registry. Also scandisk/chkdsk. Goto Start>Run>type cmd+enter. @ the cmd type
OR
To defrag the registry, use pagedefrag from www.sysinternals.com
KDE on ArchLinux
14-03-2007, 12:40 PM
Welcome To The Jungle
do as kiran has said, it will solve ur problem. i had a similar prob and then downloaded the update and everything got solved.
Me n My Canon EOS 350D with EF 50mm f1.8
15-03-2007, 03:31 AM
hey kiran,i tried downloading the file u told and running it but there was no use..the problem is still there. .seems like there is no prob while chatting with msn messenger or yahoo im.only when browsing using any browsers.
i am giving below the error report detail thats shown with it:
EventType:BEX
P1:svchost.exe
P2:5.1.2600.2180
P3:41107ed6
P4:netapi32.dll
P5:5.1.2600.2180
P6:411096ac
P7:0000a3c0
P8:c0000409
P9:0000000
Exception unknown software exception(oxc0000409) occured in application at location(0x5b86a3c0)
pls help me with this...thanx a lot...
15-03-2007, 11:54 AM
Did u install that hotfix? I am sure it is the problem with updates. Error signature also says the same thing. Are you using Genuine Windows?
Please go to windowsupdate.microsoft.com and update Windows.
Kiran Kumar R
15-03-2007, 04:54 PM
yeah kiran, iam using genuine windows xp.i got it along with my acer laptop i brought in 2005.i tried updating windows but when i try doing automatic updates also,the same error occurs.dont know wat to do.Just when it shows that error,then the data transfer in the internet comes to a complete stop.
also i want to know if there will be any use if i format the C drive and install XP once more?will that get rid of the prob?
is there any other way to get rid of the problem?pls help....
16-03-2007, 08:13 PM
yeah kiran,iam using genuine windows xp.i got it along with my acer laptop i brought in 2005.i tried updating windows but when i try doing automatic updates also,the same error occurs.dont know wat to do.Just when it shows that error,then the data transfer in the internet comes to a complete stop.
You must update your Windows. The hotfix is not installed yet. Enable "Automatic Updates" from Start > Control Panel.
Then leave the system to download the updates automatically.
If still the updates doen't get downloaded, please install "AutopatcherXP" from Digit CD or download freely from internet.
Btw, do u have HP printer? ...
Check this thread ....
ERROR RESOULTION: Generic Host Process Error Message
Kiran Kumar R
