Old 13-03-2007, 10:55 AM   #1 (permalink)
Still Shining!
Lucky_star's Avatar
Default Avi Problem
I have downloaded an AVI file yesterday. But it got corupted somehow.
Media player classic says it cannot render the file. Is there any way I can fix it so that I can play the video...or at least some portions of it...
Nokia N86 8MP
Lucky_star is offline
Old 13-03-2007, 11:36 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Avi Problem
Use Avi Fix Repair Joiner 2.11 and fix the errors. You may be able to play it. The program is a shareware.
Kiran Kumar R
Kiran.dks is offline
Old 13-03-2007, 11:47 AM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Thanx for the Link.
But that didn't solve my problem.
It says the file is not an avi file. But my friends have downloaded the same and its playing well; what happened to this
Nokia N86 8MP
Old 13-03-2007, 11:49 AM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
try playing it on VLC Media Player.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 13-03-2007, 11:52 AM   #5 (permalink)
Kiran.dks's Avatar
Did you check the file extension? Is it .avi? If yes, then I think it has totally gone corrupt. btw, which player are using to open it?
Kiran Kumar R
Old 13-03-2007, 11:55 AM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
yah its an .avi file. I used Media player classic that comes with klite. I tried by changing its extension to mpeg but that too didn't help.
@s18000rpm, vlc opens the file and the seek bar runs to the other end within one minute...no video nothing... the file is 700 MB size.
Nokia N86 8MP
Old 13-03-2007, 12:03 PM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
AVIFixed 2.0 b1 new
AVIFixed can rebuild the index part of the movie file and and fix the file's play time error.
AVImedic 5.3a
Before hunting for codecs and players or cutting out bad frames try and repair the file with AVImedic.
try these, if they too dont help, i think you will have download again.
Source of Tools::: Free-Codecs.com Fix Repair Tools
did you download from rapidshare (in parts)???
Old 13-03-2007, 12:07 PM   #8 (permalink)
The Unknown's Avatar
It may be coded in MPEG-4. Download MP4 codec & try playing it in WMP.
KDE on ArchLinux
The Unknown is offline
Old 13-03-2007, 12:11 PM   #9 (permalink)
Still Shining!
Lucky_star's Avatar
Avi medic too couldn't solve the problem. I think its totally dead. BTW, i had downloaded it from p2p
@Indyan, I have the latest version of Klite installed.
Nokia N86 8MP
Old 13-03-2007, 12:12 PM   #10 (permalink)
p2p may be the reason. Try downloading it directly if your have U/L DSL.
KDE on ArchLinux
Old 13-03-2007, 12:17 PM   #11 (permalink)
Still Shining!
Lucky_star's Avatar
I have a 256 kbps Cable modem connection . and the free download is from 1-7. I had automated the downloads. I think, I should go for direct downloads...once again.
Nokia N86 8MP
Old 13-03-2007, 12:42 PM   #12 (permalink)
Kiran.dks's Avatar
Two Probabilities at last:
1. File fully corrupted
2. May be a Google Video. Then try playing in Google Video Player. Many Google videos are also available in p2p sites.
Kiran Kumar R
Old 13-03-2007, 05:41 PM   #13 (permalink)
Still Shining!
Lucky_star's Avatar
@Indyan, I have installed Crystal Player and Gom Player now.
Crystal Player is saying "Can't Locate video stream"
while Gom is saying "Codec not found"
I think the video is of no use now. Will have to go for other sources...
Nokia N86 8MP
Old 13-03-2007, 11:49 PM   #14 (permalink)
open the file in "gspot codec information" to find the actual codec.
or try this
open media player classic.."file->utils->dsm converter->(rt clkwindow)addfile->save".try playing this dsm file in mp classic.
jay_jay is offline
Old 13-03-2007, 11:57 PM   #15 (permalink)
Still Shining!
Lucky_star's Avatar
Gspot says the Filetype as "unknown"
i tried now what you said, But when I clicked on the save as option in the DSM coverter, nothing happened; the start, pause, stop buttons are unavailable.
Nokia N86 8MP
Old 14-03-2007, 12:04 AM   #16 (permalink)
did the file opened in dsm converter
jay_jay is offline
Old 14-03-2007, 12:06 AM   #17 (permalink)
Still Shining!
Lucky_star's Avatar
there was no response at all..
Nokia N86 8MP
Old 14-03-2007, 12:12 AM   #18 (permalink)
just try in virtual dub or any such encoders
jay_jay is offline
Old 14-03-2007, 03:05 PM   #19 (permalink)
The joy Of Wow
kirangp's Avatar
Dude even after so may solutions if the file is not working then it is better u download it again...Sometimes the files are fake & are put on p2p for fun or tracking..Recording companies use these files to track users...So be careful
The right man in the wrong place can make all the difference in the world
kirangp is offline
Old 14-03-2007, 04:16 PM   #20 (permalink)
aj27july's Avatar
Open it with VIRTUALDUB MOD. AND THEN AGAIN SAVE IT USING VIRTUALDUB MOD. VIRTUALDUB MOD is free.
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 14-03-2007, 04:55 PM   #21 (permalink)
Still Shining!
Lucky_star's Avatar
The same file was Downloaded by my friend and its working.
@aj27july, I don't have much experience on Virtual Dub. I get confused with the settings.
Nokia N86 8MP
Old 14-03-2007, 10:16 PM   #22 (permalink)
aj27july's Avatar
I think that the menus are self explanatory. If you do not understand what a menu does, look on the status bar while hovering your mouse over that menu.
----OSHO
aj27july is offline
Old 14-03-2007, 10:42 PM   #23 (permalink)
Still Shining!
Lucky_star's Avatar
Ok... I will try...but will that be of any use..?
Nokia N86 8MP
- by gohan89
