Old 12-03-2007, 11:10 PM   #1 (permalink)
rajivrocks's Avatar
Exclamation Help-Pendrive not working properly!!
hi frnds,
i bought a Moserbaer pendrive 2GB model name:AZ601, last month, i have been using it but i'm experiencing a problem: whenever i remove it from Safely remove hardware wizard nothing happens, i mean no message is shown and if i remove it and again plugin i get the following error msg:
but if i restart my pc i can again access my pendrive until i eject it, the same problem continues...
i called the HP support they preferred me formatting my pc(they will always suggest restoring or formatting)...
i'm not in a mood of formatting coz last month i did format my pc due to some virus it was such a pain...
please guyz help me with your valuable suggestion...
P.S.-i'm using HPW5030IN
Windows xp wth service Pack2
-i tried my pendrive on my friends pc and its working fine.
rajivrocks is offline
Old 12-03-2007, 11:22 PM   #2 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
Default Re: Help-Pendrive not working properly!!
may be ur usb point is not working properly....try inserting it into a diff. usb point.
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 12-03-2007, 11:27 PM   #3 (permalink)
rajivrocks's Avatar
thnx for ur reply i tried it for sure but stil the problem continues...
Old 12-03-2007, 11:28 PM   #4 (permalink)
The Unknown's Avatar
Try it on a different USB port or on ur frnd's computer.
KDE on ArchLinux
The Unknown is offline
Old 12-03-2007, 11:33 PM   #5 (permalink)
rajivrocks's Avatar
its running fine on my frnds pc, i tried it on almost 4-5 frnds pc its runnin SAFE nd good..
the problem lies in my pc so please help reagarding that, thanx anywayz
Old 12-03-2007, 11:36 PM   #6 (permalink)
Buddy, buy a new USB card of Tech-Com or Intex and fix it in the PCI slot. Each one of them have 5-6 USB ports and everything works fine on them. I have in total 12 USB ports in my BOX.
KDE on ArchLinux
Old 12-03-2007, 11:38 PM   #7 (permalink)
rajivrocks's Avatar
couldnt get you what is a USB card??
are you talking about USB ports??
Old 12-03-2007, 11:40 PM   #8 (permalink)
A PCI=>USB card is a card in which we can fix USB appliances.
KDE on ArchLinux
Old 15-03-2007, 10:32 PM   #9 (permalink)
sumeetindia's Avatar
If using an too long extension for USB .Then it may not work.
Have u tried this pendrive in some other P.C.
have u tried inserting and ejecting drive by computer management
(Procedure:
rt click my comp->Manage->got removable storage in left hand side pane->
Select ur pendrive ->Rt click select eject and then inject)
BTW If its pain to format your PC eveytime Then I will suggest u o use NORTON GHOST.
Make a fresh installation and make a backup of entire drive.(Use compression to save space)
The backup and restore operations don't take more than 10~15 mins
sumeetindia is offline
Old 15-03-2007, 10:38 PM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
Are you using Windows XP SP2 with all updates?
b'coz when my cousin's Laptop had XP Pro (non SP2) it also gave these kind of error, but these errors never occured after SP2 was installed on that Laptop.
sometimes, when i plugged in my Camera (thru USB), that XP Pro wud identify it as a new Hard Drive & request for a Restart (as XP wud install proper drivers for Non existent HDD, confusing isnt it? )
EDITED
try Standard Recovery, it'll not format any drive, it'll just Install XP in C: Drive, without affecting the files there & in other Drives.
+++>>or remove the USB connector frm m/b-> Boot->Shutdown -> re-insert the cables-> boot again.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 16-03-2007, 12:51 AM   #11 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
I Think You Are Using cursor xp it Has Many Bugs And Virus Just Have A Check That You May Not be Having Virus Because From My Point Of View Nothing Seem
To Be A Problem with Your Pen drive It's Exactly The Virus Which May Be Showing Irrelevant Messages
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 16-03-2007, 01:15 AM   #12 (permalink)
dOm1naTOr's Avatar
Try formatting the thump drive and install latest autopatcher, so that winxp uses latest USB drivers and fix most bugs.
Also do a virus scan with AVG 7.6 and install Ad-aware latest and remove any adware,malware or trackers.
Also on folder options> enable 'show hidden files nd folders' and also uncheck "hide protected operating system files" and see if there is any hidden exe files or somethin in ur thump drive.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
- by gohan89
