Old 12-03-2007, 05:21 PM   #1 (permalink)
Shasanka_Gogoi's Avatar
Default Clamwin Antivirus (portable apps) HELP!!!!!!
Is anyone using Clamwin Antivirus (portable app). I want to use it but the updates are to be downloaded first and that is taking over 40 mins and is still not complete moreover it doesn't shows the status. I m on a dial-up so it will take time but I don't know how much, I don't even know if its downloading the updates. Can any one please tell me where can I find only the updates for download seperately and whats its size? Thanks...........
Shasanka_Gogoi is offline
Old 12-03-2007, 05:38 PM   #2 (permalink)
prasad_den's Avatar
Default Re: Clamwin Antivirus (portable apps) HELP!!!!!!
I don't know the DL site separately, but after a fresh installation, updates alone come to around 5 to 6MB...!!
prasad_den is offline
