Old 11-03-2007, 11:12 PM   #1 (permalink)
Exclamation DVD writing problem
hi friends.. i have problem of copying and writing dvdi have formatted pc n reinstalled all...but if i copy r write dvd/cd it is taking more time..and no audio n video files r playing properly(giving rubbish sounds in middle),(before formatted writing time is 15 min, now it nearly 1 hr)i don't know is software problem or hardware?i have tried by changing nero version also and also reinstalled drivers also , but iam not...plz give a suggestion to my problem..thanq in advance....
sreenivasj is offline
Old 11-03-2007, 11:17 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: DVD writing problem
have u turned on the DMA???
what s/w u use for burning???
which dvd writer u use??
OS??
wizrulz is offline
Old 11-03-2007, 11:25 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
DVD writing may be taking 1.5 hours and copying a DVD will be taking 1 hour....right?
Try resetting the DMA
Use this tool
Else, reinstalling XP will solve the problem.
Nokia N86 8MP
Lucky_star is offline
Old 12-03-2007, 12:21 PM   #4 (permalink)
hi friend ..
thanks 4 reply...
what is DMA tool...?
__________
iam using nero 7.2 version to burn dvds....
writer is LG 18X- RW
__________
thank u 4 reply...
Old 12-03-2007, 12:29 PM   #5 (permalink)
rajasekharan's Avatar
# Under DEVICE MANAGER, open IDE ATA/ATAPI CONTROLLERS.
# On the PRIMARY and SECONDARY IDE CHANNELS, open up their PROPERTIES display.
# In PROPERTIES click on the ADVANCED SETTINGS tab.
# Make sure that TRANSFER MODES is set to DMA IF AVAILABLE. and not PIO
steps to enable DMA...
http://www.md4pc.com/questions/62.htm
Make a day good , and another day good , and another ...a happy lad is "born" from you
rajasekharan is offline
Old 12-03-2007, 12:46 PM   #6 (permalink)
Desperado's Avatar
Unhappy Re: DVD writing problem
i have had the same problem.
after changing the IDE settings to DMA - the time taken to burn a dvd was about 10 mins...
but i cant play movies on DMA mode...
i have to change it to PIO only = to play movies... and that too with funny noises in between same as srinivasan experienced.
(If i use Nero showtime player- the funny noises are gone)
Friendly Neighbourhood,
Shahid
Desperado is offline
