Old 11-03-2007, 03:18 AM   #1 (permalink)
Unhappy alt+ctrl+del...plz help
i installd windows xp manager on my laptop a few days bk...nd since thn i m nt able to use task manager(alt+ctrl+del)...
actually its nt responding...
.n nothin happens..i hv uninstalled it nw... bt its still d same...
cn ny1 help???
dcool1 is offline
Old 11-03-2007, 05:13 AM   #2 (permalink)
Wannabe_a_techie's Avatar
Default Re: alt+ctrl+del...plz help
You can open "Task Manager" in another way:
right-click on an empty space on the "Task Bar" at the bottom of your screen...one of the options will be "Task Manager".
Choose that and it will open. Then you can check the options, or the help section of Task Manager, to solve your alt+ctrl+del problem.
Wannabe_a_techie is offline
Old 11-03-2007, 08:06 AM   #3 (permalink)
sam_1710's Avatar
ctrl+shift+esc also invokes the task manager... you may try tat!!
sam_1710 is offline
Old 11-03-2007, 08:35 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
open notepad and copy paste below bold lines...save it as xyz.reg and double click it .This will fix ur problem.
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\System]
"DisableTaskMgr"=dword:0
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 11-03-2007, 11:00 AM   #5 (permalink)
uchiha.sasuke's Avatar
check the options in Windows Xp Manager dat u might had been changed by mistakenly .........
@ravi..
i dont think this will work here...b'coz he has has mentioned that nothing happened on open task manager......this key works if task manager has been disabled.......in dat case message comes showing dat it has been disabled by administrator...
uchiha.sasuke is offline
Old 11-03-2007, 07:41 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
@dcool1 ..plz try my method..and than post ur result.I want to see the result.
TechTin.com
Old 12-03-2007, 02:35 AM   #7 (permalink)
Unhappy Re: alt+ctrl+del...plz help
i hv already tried openin frm taskbar...
bt its nt wrkin frm thr too...
dcool1 is offline
Old 17-03-2007, 07:52 PM   #8 (permalink)
ravi i tried ur method..bt it dint wrk... it shows that it is usd by sm othr application..
dcool1 is offline
Old 17-03-2007, 09:48 PM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
^^^^^^^^^is ur problem solved or u r still struggling??
TechTin.com
Old 18-03-2007, 10:40 AM   #10 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Hello dcool Follow this steps
Goto Run
Type gpedit.msc
goto userconfig/administrator/system/ctrl+alt+del/RemoveTaskManagerOption and set as "not configured"
Problem will be solved
Kaushal Hiwarkar is offline
Old 18-03-2007, 12:07 PM   #11 (permalink)
pritish_kul2's Avatar
^^^^ if he has XP Pro
pritish_kul2 is offline
Old 18-03-2007, 12:59 PM   #12 (permalink)
The Blessed one
Can you try this please:
Open the Run dialog and type taskmgr.exe
fatguysmart is offline
