Old 10-03-2007, 10:07 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
tinku dhar's Avatar
Default How to Extract .bin / .cue
well ... ,
can anyone give me a appz wich can extract this .bin files ?
i have downloaded a appz wich is in this format sooo send me the link sooon
take care
tinku dhar is offline
Old 10-03-2007, 10:24 PM   #2 (permalink)
tinku dhar's Avatar
Default Re: How to Extract .bin / .cue
without usin the burner can't we extract it ?
i heard we can frm some place and there is a appz for tht to do
Old 10-03-2007, 10:30 PM   #3 (permalink)
tinku dhar's Avatar
well ... ,
im waitin for some other replies
also i think we can do in NERO but i don't want to use any burner apppz
Old 11-03-2007, 12:55 AM   #4 (permalink)
CG Artist
gaurav_indian's Avatar
Use this one.
http://www.magiciso.com/tutorials/miso-whatsimage.htm
gaurav_indian is offline
Old 11-03-2007, 01:00 AM   #5 (permalink)
winrar can extract from bin/iso files, you need to set the file association in winrar options
ranjan2001 is offline
Old 11-03-2007, 01:03 AM   #6 (permalink)
thunderbird.117
Posts: n/a
Use Ultra ISO which is very easy to do or download daemon tools or alchol 42% and mount the image and do whatever you like. If you use ultraiso or magiciso you can extract any images.
Old 11-03-2007, 09:43 AM   #7 (permalink)
tinku dhar's Avatar
Talking Re: How to Extract .bin / .cue
ok guys i will try
but if u get any nice particular appz send me
__________
Originally Posted by gaurav_indian
well actually i have got ..... ,
CD1 .bin and CD2 .bin do i need to copy in CD or this appz can do frm PC ?
thnx
REP ++
Old 11-03-2007, 10:05 AM   #8 (permalink)
The Unknown's Avatar
try googling wth the keywrd "software to extract .cue/.bin files" or u can use Ashampoo Burning Studio- Free to write them to a CD/DVD.
__________
www.google.co.in
KDE on ArchLinux
The Unknown is offline
Old 11-03-2007, 01:44 PM   #9 (permalink)
Google Bot
Pathik's Avatar
u can extract it using winrar also...
and bin files are cd images... to use them load them in any virtual drive soft like daemon tools..
Pathik is offline
Old 11-03-2007, 02:11 PM   #10 (permalink)
CG Artist
Originally Posted by tinku dhar
ok guys i will try
__________
thnx
REP ++
Open the .bin file in magiciso,press ctrl+a and right click and select extract.You can extract it to any folder.
Old 14-03-2007, 08:11 PM   #11 (permalink)
tinku dhar's Avatar
ok .... ,
i have not tried it yet will try it tut. out now .....
Thnx
PEACe
Old 14-03-2007, 10:12 PM   #12 (permalink)
aj27july's Avatar
Use Daemon Tools. Install it. Run it. in the task bar, right click the daemon tools icon, select Virtual CD\DVD ROM-->Device O--> mount image.
Now in the dialog that opens, select the cue image. Press ok. Open MY COMPUTER. you should see a virtual CD\DVD DRIVE on which the contents of the cue file are loaded.
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 17-03-2007, 04:36 PM   #13 (permalink)
tinku dhar's Avatar
if i extract it will i be able to install ?
as i said i have 2 parts
CD1.bin and CD2.bin
reply fast
Old 17-03-2007, 06:09 PM   #14 (permalink)
CG Artist
CD1.bin and CD2.bin
reply fast
Is there is a setup.exe in CD1.bin and CD2.bin then why not.
Old 17-03-2007, 06:43 PM   #15 (permalink)
tinku dhar's Avatar
Welll .... ,
Dude there is Setup.exe in CD1 and but in CD2 its Hiphopejay.exe
Suld i show u the screenshots ?
Old 17-03-2007, 06:54 PM   #16 (permalink)
deadpulse's Avatar
USe Win RAR it supports .cue and .bin images.
"Attitude is not walking like a King, it's walking like I don't care who the King is......"
deadpulse is offline
Old 17-03-2007, 07:09 PM   #17 (permalink)
nishant_nms's Avatar
Use Deamon Tools
nishant_nms is offline
Old 18-03-2007, 05:44 PM   #18 (permalink)
tinku dhar's Avatar
Ooooooooooooooooo thnx guys .... ,
MAGICISO is workin for me thnx
Old 18-03-2007, 05:50 PM   #19 (permalink)
CG Artist
Thank God finally.
Old 18-03-2007, 06:36 PM   #20 (permalink)
Booting Nicotine!!
spironox's Avatar
"IsoBuster" should do the tricks for you .. i am using it and i am happy with it
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
spironox is offline
Old 18-03-2007, 07:04 PM   #21 (permalink)
tinku dhar's Avatar
No i have done usin magisiso
GAURAV mayn REP ++
Old 18-03-2007, 07:12 PM   #22 (permalink)
Booting Nicotine!!
spironox's Avatar
ok as thou wish !!
spironox is offline
Old 18-03-2007, 09:32 PM   #23 (permalink)
CG Artist
GAURAV mayn REP ++
You havent given me reps.
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/52004-how-extract-bin-cue.html
does winrar extract .bin .cue - Google Search This thread Refback 08-02-2011 07:56 AM
