Old 10-03-2007, 02:07 PM   #1 (permalink)
Question drives not opening
hi friends,
i have problem in opening the drives of my computer,when i double click on any drive its open in next window,i have checked in tools option that is also correct it shows open next window in same window option is also enable,
when i right click on any drive the first options in right click menu is open(0)
then next is Auto play then search then open.
but in others pcs the right click option menu first option is just open.
i have reinstall 2 to 3 times o.s i.e. xp.but still i have same problem so any one have face this problem so tell the solution for it or any one know for same....................thanx
Naveed is offline
Old 15-03-2007, 08:51 PM   #2 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Default Re: drives not opening
In windows explorer
1. Go to "Tools-->Folder Options"
2. Select the "File Types" tab
3. Select the file type of "Folder".
4. Click on "Advanced"
5. Under the "Actions" select "Open"
6. Click on "Set Default"
7. Click OK
You can also delete the open(0) option if required
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
