Old 10-03-2007, 10:52 AM   #1 (permalink)
Exclamation problem add remove programs
Ive uninstall (its a game courage under fire) the software from the programs but it still shows in the add remove programs how can i remove it plz help
venket_sushant is offline
Old 10-03-2007, 10:57 AM   #2 (permalink)
The Unknown's Avatar
Default Re: problem add remove programs
probab;y it needs some registry modifications. pm Vishal Gupta. He can help you.
KDE on ArchLinux
The Unknown is offline
Old 10-03-2007, 11:29 AM   #3 (permalink)
Kiran.dks's Avatar
> Start
> Run
> Type "regedit" and click OK
> Open HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Uninstall
> Remove the corresponding entry from the list.
> Close Registry editor
Alternatively you can use Windows Installer Clean-up utility for cleaning unwanted entries.
Kiran Kumar R
Kiran.dks is offline
Old 10-03-2007, 11:31 AM   #4 (permalink)
Originally Posted by Kiran_tech_mania
> Start
> Run
how about CCleaner? www.ccleaner.com/download/
I guessed this from your post! Also i use CCleaner to clean my registry.
KDE on ArchLinux
Old 10-03-2007, 11:46 AM   #5 (permalink)
Kiran.dks's Avatar
Ccleaner is not effective in cleaning invalid registry entries. It is a good junk file cleaner.
WinXP Manager has one of the best Registry cleaner. It is a paid program.
Kiran Kumar R
Old 10-03-2007, 11:48 AM   #6 (permalink)
junk files? wht do u mean?
KDE on ArchLinux
Old 10-03-2007, 11:51 AM   #7 (permalink)
Kiran.dks's Avatar
Junk files are the useless system left over files.
Kiran Kumar R
Old 10-03-2007, 12:07 PM   #8 (permalink)
Google Bot
Pathik's Avatar
i prefer to use Ccleaner and Tuneup
Pathik is offline
Old 10-03-2007, 12:09 PM   #9 (permalink)
buddy, u only gave me the info abt CCleaner!
KDE on ArchLinux
Old 10-03-2007, 12:09 PM   #10 (permalink)
Arsenal_Gunners's Avatar
A thread like this was recently created
windows xp uninstall help
Arsenal_Gunners is offline
