Old 09-03-2007, 11:05 PM   #1 (permalink)
Exclamation Window XP installation problem
im installing XP using Dos i hav commanded "D:\i386\winnt" then blue screen appears and it says
An internal Setup error occurred.
Could not find a place for a swap file.
Setup cannot continue. press ENTER to exit.
Please tell me wat 2 do and how 2 do.
Please help me u can also contact me at
mohsin_a_b@yahoo.com
or
mohsinonfire@gmail.com
oh yeah is offline
Old 09-03-2007, 11:07 PM   #2 (permalink)
shantanu's Avatar
Default Re: Window XP installation problem
r u using NON-genuine OS... and installing from a dump..
shantanu is offline
Old 09-03-2007, 11:37 PM   #3 (permalink)
PrinceHeart's Avatar
Make a Win 98 Boot floopy with CD Support.
Download the Windows 98 SE boot disk from Bootdisk.com
Insert both Floppy n WinXP CD inside floppy n cd drive respectively.
Change Boot Preference to Floppy in Bios.
Restart PC.
Boot the PC from floopy.
Then try to install WinXP.
Note: Can do the same if D drive is a hard disk partition and WinXP files are dumped in a folder.
Hope it helps.
Cheerz
*PrInCe*
PrinceHeart is offline
Old 10-03-2007, 01:14 PM   #4 (permalink)
thank u prince but 1 more problem my laptop on which im installing dosent have floppy drive....;
can i boot my pen drive.
oh yeah is offline
Old 10-03-2007, 03:35 PM   #5 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Don't Try To Install It From Dos Just Insert Your Cd Select First Booting Device As cd Rom Then The Setup WIll Start Follow The Instructions And You Are Done
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 10-03-2007, 06:24 PM   #6 (permalink)
The Unknown's Avatar
Burn XP setup to CD and Install XP from the CD.
KDE on ArchLinux
The Unknown is offline
Old 11-03-2007, 03:24 PM   #7 (permalink)
oh_yeah - Just make a bootable startup cd and boot from it 1st and then install winxp from ur hard disk - or u can always burn the winxp installation and make a bootable OS disc and install directly from CD - as told by The Unknown.
Hope it helps.
Cheerz
Edited the Nick ID.
*PrInCe*
Old 11-03-2007, 03:30 PM   #8 (permalink)
Originally Posted by PrinceHeart
oh_yeah - Just make a bootable startup cd and boot from it 1st and then install winxp from ur hard disk - or u can always burn the winxp installation and make a bootable OS disc and install directly from CD - as told by The_Unknown.
Hope it helps.
Cheerz
u guys always misspell me. my id is The Unknown.
KDE on ArchLinux
- by gohan89
