Old 09-03-2007, 05:21 PM   #1 (permalink)
bajaj151's Avatar
Default Drive Not opening...plz help...
One of my partiation not opening......and shows this error
G:\ is not accesible.
The disk structure is corrupted or unreadable.
I dont know.....how this happened....i have not formatted this partition...
Plz...tell me how can i recover my lost partition......
Thxxxx
bajaj151 is offline
Old 09-03-2007, 05:36 PM   #2 (permalink)
Too hot for this forum.
Default Re: Drive Not opening...plz help...
did someone else have access to your pc?
if so, maybe dat partition has been "locked' using a program.
if data present isnt' important,just format the thing.
Life's too short.Why use Dialup?
s_aerin is offline
Old 09-03-2007, 05:47 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Thxxxx
TRY USING THESE TWO SITES
How to perform disk error checking in Windows XP
http://www.microsoft.com/resources/d....mspx?mfr=true
else u have t o format ur drive
wizrulz is offline
Old 09-03-2007, 06:08 PM   #4 (permalink)
uchiha.sasuke's Avatar
have to format i guess..........m not sure so plz wait for more replies
uchiha.sasuke is offline
Old 09-03-2007, 06:51 PM   #5 (permalink)
deadpulse's Avatar
Better check it in DOS mode if still it wont allow you to access the drive you need to check it on mounting on other system. Still not worked then last option format it and well check it by disk manager.
"Attitude is not walking like a King, it's walking like I don't care who the King is......"
deadpulse is offline
Old 09-03-2007, 07:53 PM   #6 (permalink)
The Unknown's Avatar
google. it cud gv u some answers. www.google.co.in
KDE on ArchLinux
The Unknown is offline
- by gohan89
